1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ai record with dtyp of "raw soft channel"
To: [email protected]
Date: Thu, 02 Apr 2009 18:07:17 -0700
I'm trying to use an ai record to obtain the value of a channel from a record on another IOC. I have the INP field set to "(name of field on other IOC) CP"; When I specify the DTYP as Soft Channel, it reads the value and updates as it changes. But when I set the DTYP to Raw Soft Channel so that I can do conversion on it, both the RVAL and the VAL fields stay a constant 0.
Thank you,
Patrick
Re: ai record with dtyp of "raw soft channel" Dirk Zimoch
Re: ai record with dtyp of "raw soft channel" Ralph Lange
Prev: Re: dbLoadTemplate and includes Emmanuel Mayssat
Next: Asyn changes Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: ai record with dtyp of "raw soft channel" Dirk Zimoch
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
