1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ai record with dtyp of "raw soft channel"
To: Patrick Thomas <[email protected]>
Cc: [email protected]
Date: Fri, 03 Apr 2009 08:45:23 -0400
Hi Patrick,
in principle your database should work as you expect ...
Please check:
Is your link connected properly (or do you see a record status of LINK)?
If you're changing the DTYP online, you will have to set the INP field afterwards or your DTYP change will be unnoticed. In many cases, it is important that in the database file the DTYP field appears *before* the INP/OUT link fields (else parsing the link field might go wrong).
Good luck!
Ralph
On 02.04.2009 21:07 Patrick Thomas wrote:
I'm trying to use an ai record to obtain the value of a channel from a record on another IOC. I have the INP field set to "(name of field on other IOC) CP"; When I specify the DTYP as Soft Channel, it reads the value and updates as it changes. But when I set the DTYP to Raw Soft Channel so that I can do conversion on it, both the RVAL and the VAL fields stay a constant 0.
Thank you,
Patrick
ai record with dtyp of "raw soft channel" Patrick Thomas
Prev: Re: EPICS at exit memory leak Andrew Johnson
Next: JCA memory leaks w/ older EPICS base or JVM Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ai record with dtyp of "raw soft channel" Dirk Zimoch
Next: Asyn changes Eric Norum
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
