Hi Patrik,
I tried it and it works. You did not try to set the INP link to the RVAL field
of the other record (which is not Raw Soft Channel), did you?
Also keep in mind that the RVAL field is an integer. Thus pointing the INP to a
double field will round the value (eventually to 0).
Dirk
Patrick Thomas wrote:
I'm trying to use an ai record to obtain the value of a channel from a
record on another IOC. I have the INP field set to "(name of field on
other IOC) CP"; When I specify the DTYP as Soft Channel, it reads the
value and updates as it changes. But when I set the DTYP to Raw Soft
Channel so that I can do conversion on it, both the RVAL and the VAL
fields stay a constant 0.
Thank you,
Patrick
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- ai record with dtyp of "raw soft channel" Patrick Thomas
Re: Asyn changes Eric Norum
Re: EPICS at exit memory leak Andrew Johnson
<2009>
2025
2026
Re: ai record with dtyp of "raw soft channel" Ralph Lange
<2009>
2025
2026
