1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Remote IOC reboot [was: EPICS for implementation of Remote Procedure Call]
To: Emmanuel Mayssat <[email protected]>
Cc: [email protected]
Date: Thu, 16 Apr 2009 10:57:58 +0200
Hi Emmanuel,
as Stephanie points out, a simple sub record allows for CA based reset on most IOC platforms. (No special device support necessary.)
Remember, though, there are cases when this will or might not work: IOC hangs (so the IOC doesn't work), IOC gets CPU saturated (so that CA doesn't work), IOC gets memory saturated (so that CA doesn't allow new connections). In those cases, you will probably have to get to the console of the IOC and do whatever necessary (e.g. type ^X). Workaround: it is relatively easy to create a shell script that connects to the console and echoes a ^X to it, so you can still create a GUI button that calls the shell script that connects to the console and reboots the IOC. Less elegant than CA to a sub record, still more efficient than walking over.
Also, for VME based systems, there are situations that need a VME reset rather than just a reboot of the CPU. Some VME crates (e.g. those by Wiener) are remotely controllable, so that the whole VME crate can be switched on/off or reset remotely (plus a bucket load of other functionality). For other (aka less expensive) crates some labs have developed VME cards that can be remotely accessed and are able to pull the VME reset line (plus more functionality). That is not free: A separate card always uses an extra slot.
Cheers,
Ralph
On 15.04.2009 20:42 Allison, Stephanie wrote:
Hi Emmanuel,
There are some device support packages that provide for rebooting/restarting an IOC via record.  For instance, devIocStats:
http://www.slac.stanford.edu/comp/unix/package/epics/site/devIocStats/
provides a sub record that calls epicsExit for soft iocs, reboot for vxWorks iocs, and bsp_reset/rtemsReboot for RTEMS iocs.
Stephanie Allison
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Emmanuel Mayssat
Sent: Wednesday, April 15, 2009 11:26 AM
To: [email protected]
Cc: Mahajan Kirti; [email protected]
Subject: Remote IOC reboot Was(EPICS for implementation of Remote Procedurecall)
S,
Could you describe your interface (from a user/operator perspective) to
your IOC reboot interface? I may actually be interested with that.
In short I want to know:
Can you reboot/control a remote IOC with the push of a GUI button?
Emmanuel
RE: Remote IOC reboot [was: EPICS for implementation of RemoteProcedure Call] Dalesio, Leo
Re: Remote IOC reboot [was: EPICS for implementation of Remote Procedure Call] Rolf Keitel
EPICS for implementation of Remote Procedure call Mahajan Kirti
Re: EPICS for implementation of Remote Procedure call Andrew Johnson
Re: EPICS for implementation of Remote Procedure call S. Banerian
Remote IOC reboot Was(EPICS for implementation of Remote Procedure call) Emmanuel Mayssat
RE: Remote IOC reboot Was(EPICS for implementation of Remote Procedurecall) Allison, Stephanie
Prev: where to download elog? Silver
Next: RE: Remote IOC reboot Was(EPICS for implementation of RemoteProcedurecall) Pearson, MR (Matthew)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Remote IOC reboot Was(EPICS for implementation of Remote Procedurecall) Allison, Stephanie
Next: RE: Remote IOC reboot [was: EPICS for implementation of RemoteProcedure Call] Dalesio, Leo
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
