1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problems using the sscan record
To: <[email protected]>
Date: Mon, 20 Apr 2009 12:41:54 +0800
Hi all,
We have some problem in using sscan records with one motor as one positioner and one ADC value from the detector.
Hardware: VME+MVME5500+MAXv-8000
Software: EPICS base3.14.8+MotorR6-2-2+Sscan from synApps5_2 + (some transform records)
The problem happens frequently when the scan is processing . When it happens:
1. All the PVs on the EDM interface are connected, but no motor (residing in this IOC) has any response to the new setting value of its Motor.DVAL. It seems the IOC doesnt accept command from OPI any more;
2. The commands like dbl are still working normally on the minicom console;
3. The network between OPI and IOC is ok;
4. When restart the IOC by typing the reboot command on the minicom console, the IOC cant be recovered normally.
5. The IOC have to be restarted by powering off and on.
We also tried to split sscan to a PC/Linux/IOC, the problems still appear.
Any suggestion and idea are welcomed.
Zhaohong
ZhaoHong Zhang
Beamline control group Dept. of Beamline Engineering
Shanghai Synchrotron Radiation Facility(SSRF)
Shanghai Institute of Applied Physics
Chinese Academy of Sciences
239 Rd.Zhangheng,Pudong,Shanghai 201203
China
Tel: 021-33933238
Email:
[email protected]
RE: Problems using the sscan record Mark Rivers
Prev: RE: CAS server and partial vectors Bruno Coudoin
Next: Re: Genesys Power Suppy LAN driver Burkhard Kolb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: NTPTimeSync timeout messages on VxWorks with EPICS 3.14.10 Andrew Johnson
Next: RE: Problems using the sscan record Mark Rivers
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
