1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Genesys Power Suppy LAN driver
To: [email protected]
Cc: "Tagle, Jerico" <[email protected]>
Date: Mon, 20 Apr 2009 09:44:12 +0200
Hello Jerico,
we also use several "GENESYS" power supplies with asyn and stream.
To the LAN part I have to add the following.
There exist at least three different implementations of the IP interface:
1. Agilent supllies one which uses TCP/IP. It works in principle
but stops working under heavy network load in our network. Agilent
was not able to reproduce this error, but we have several power supplies and also other equipment from them which just quits responding on TCP/IP.
The power stays on - to regain control a power cycle is needed.
2. TDK Lambda produces the same line of power supplies. Actually, the
power part is made by them also for the other vendors.
There standard ethernet interface uses a "raw ethernet" with modified
headers - so you have to patch asyn if you want to use this.
3. TDK Lambda agreed (on customer request) to provide an alternate
ethernet interface, based on TCP/IP. This is what we use now - it works very well, even under our heavy loaded network conditions.
Burkhard Kolb
Dirk Zimoch wrote:
Hello Jerico,
It should be sufficient to replace the drvAsynSerialPortConfigure like in your startup script with a drvAsynIPPortConfigure line.
If the device uses the vxi11 protocol ("GPIB over ethernet") use a vxi11Configure line instead.
Dirk
Tagle, Jerico wrote:
Greetings All,
My name is Jerico Tagle and I work at SLAC National Accelerator Labaratories in Menlo Park, CA. We have successfully communicated with the Genesys 300-17 via RS232 on EPICS (Thanks to Mr Dennis Armstrong @ PSI) and would like to communicate with it via LAN. If you have existing drivers for the Genesys power supplies via LAN, can you please send me a copy? My forte is Power Electronics and I am attempting to learn EPICS to control our power supplies for the future.
Thnks For Your Time!
Jerico Tagle
Dr. Burkhard Kolb
HADES
E-Mail: [email protected]
Tel: +49-(6159)-71-2667 / Fax: +49-(6159)-71-2185
GSI Helmholtzzentrum für Schwerionenforschung GmbH
Planckstraße 1 / D-64291 Darmstadt / www.gsi.de
Gesellschaft mit beschränkter Haftung
Sitz der Gesellschaft: Darmstadt
Handelsregister: Amtsgericht Darmstadt, HRB 1528
Geschäftsführer: Professor Dr. Horst Stöcker, Christiane Neumann
Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph
Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
Genesys Power Suppy LAN driver Tagle, Jerico
Re: Genesys Power Suppy LAN driver Dirk Zimoch
Prev: Problems using the sscan record 张招红
Next: Motor record compilation error under win32-x86 Wang Xiaoqiang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Genesys Power Suppy LAN driver Dirk Zimoch
Next: EPICS driver for vacuum devices Xu, Huijuan
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
