1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Motor record compilation error under win32-x86
To: "epics" <[email protected]>
Date: Mon, 20 Apr 2009 14:47:49 +0200
When I compile motor 6-4-2 under win32-x86 with vs2008 (cl version
14.00.50727.762), it reports the following errors:
make[1]: Entering directory
`/c/epics/synApps_5_4/support/motor/6-4-2/motorApp/MotorSrc/O.win32-x86'
Installing generic include file ../../../include/motor.h
cl /nologo /EHsc /GR -c                /D_CRT_SECURE_NO_DEPRECATE
/D_CRT_NONSTDC_NO_DEPRECATE /D__STDC__=0   /Ox /GL   /W3 /w44355
/MT -DEPICS_DLL_NO   -I. -I..\\O.Common -I. -I..
-I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include
-Ic:\\epics\\synApps_5_4\\support\\asyn\\4-10\\include
-Ic:\\epics\\synApps_5_4\\support\\seq\\2-0-12\\include
-Ic:\\epics\\base-3.14.10\\include\\os\\WIN32
-Ic:\\epics\\synApps_5_4\\support\\motor\\6-4-2\\include       /Tp
..\\motorRecord.cc
motorRecord.cc
c:\epics\synapps_5_4\support\motor\6-4-2\motorapp\motorsrc\motor.h(126)
: error C2014: preprocessor command must start as first nonwhite space
: fatal error C1017: invalid integer constant expression
make[1]: *** [motorRecord.obj] Error 2
make[1]: Leaving directory
make: *** [install.win32-x86] Error 2
In motor.h(126): #if defined(_WIN32) || #cpu(i386) || defined (_M_IX86)
|| defined (_X86_),
the #cpu(i386) assertion confuses compiler. If I split it over two lines
then it works.
#if defined(_WIN32) || defined (_M_IX86) || defined (_X86_)
    #define LSB_First (TRUE)  /* LSB is packed first. */
#elif #cpu(i386)
It seems MSVC does not accept directives mixed.
Dr. Xiaoqiang Wang
Paul Scherrer Institut, WBGB/010
5232 Villigen PSI, Switzerland
Re: Motor record compilation error under win32-x86 Ron Sluiter
Prev: Re: Genesys Power Suppy LAN driver Burkhard Kolb
Next: RE: Problems using the sscan record Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: 答复: Problems using the sscan record 张招红
Next: Re: Motor record compilation error under win32-x86 Ron Sluiter
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
