It sounds like some task may be crashing in the IOC.
Since commands like dbl are working, you should do command like the following:
i
checkStack
mbufShow
You need to figure out if a task has stopped, if the network stack is not working, etc.
Can you ping the IOC when that happens?
Sent: Sun 4/19/2009 11:41 PM
To: [email protected]
Subject: Problems using the sscan record
Hi all,
We have some problem in using sscan records with one motor as one positioner and one ADC value from the detector.
Hardware: VME+MVME5500+MAXv-8000
Software: EPICS base3.14.8+MotorR6-2-2+Sscan from synApps5_2 + (some transform records)
The problem happens frequently when the scan is processing . When it happens:
1. All the PVs on the EDM interface are connected, but no motor (residing in this IOC) has any response to the new setting value of its Motor.DVAL. It seems the IOC doesn't accept command from OPI any more;
2. The commands like 'dbl' are still working normally on the minicom console;
3. The network between OPI and IOC is ok;
4. When restart the IOC by typing the 'reboot' command on the minicom console, the IOC can't be recovered normally.
5. The IOC have to be restarted by powering off and on.
We also tried to split sscan to a PC/Linux/IOC, the problems still appear.
Any suggestion and idea are welcomed.
Zhaohong
ZhaoHong Zhang
Beamline control group Dept. of Beamline Engineering
Shanghai Synchrotron Radiation Facility(SSRF)
Shanghai Institute of Applied Physics
Chinese Academy of Sciences
239 Rd.Zhangheng,Pudong,Shanghai 201203
China
Tel: 021-33933238
Email: [email protected] <mailto:[email protected]>
- 答复: Problems using the sscan record 张招红
- Problems using the sscan record 张招红
Motor record compilation error under win32-x86 Wang Xiaoqiang
Re: Motor record compilation error under win32-x86 Ron Sluiter
<2009>
2025
2026
<2009>
2025
2026
