1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CSS Update
To: "Kasemir, Kay" <[email protected]>
Cc: tech talk <[email protected]>
Date: Mon, 18 May 2009 12:04:15 -0500
Thanks Kay!
I wasn't sure if the "EPICS PV Tree" was meant to replace probe or not.
When run the first time and the Welcome screen with the setup instructions is open, the Data Browser would not open--it doesn't look like it creates it's own perspective. After I opened another perspective, the Data Browser opened and runs fine.
Brian
Kasemir, Kay wrote:
Hi:
You're right that "Probe" was simply missing in the
"Basic EPICS" version of CSS.
So was the Preference GUI for configuring Channel Access.
Sorry for having overlooked that. Guess Friday is not a
good time for publishing stuff.
The web page now has new binaries:
 http://ics-web.sns.ornl.gov/css/products.html
The Data Browser should have been OK and still works for me under
OS X (Java 1.5), Redhat Linux  (Java 1.5) and Windows XP (Java 1.6),
so we'll have to figure out why that's not working for you.
On 5/18/09 10:31 , "tieman" <[email protected]> wrote:
I've downloaded the "Basic EPICS" version of CSS.  I don't see "probe"
under Diagnostic Tools. ...
Nothing appears to happen when I select Date Browser from the Trends
menu...
Is there a log file to look at to see what the problem might be?
Yes, it's a file
  .metadata/.log
in the workspace directory, which defaults to
  <your home directory>/CSS-Workspaces/Default .
Check the CSS File/Switch Workspace... menu option
to see the current workspace.
-Kay
Re: CSS Update Kasemir, Kay
Prev: Re: Re: Implementation of an EPICS IOC on an Embedded Soft Core ProcessorUsing Field Programmable Gate Arrays Silver
Next: Re: CSS Update Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CSS Update Kasemir, Kay
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
