Maybe anyone can update EPICS Base 3.14.10 baseR3.14.10.tar.gz file in
page
http://www.aps.anl.gov/epics/download/base/index.php?
Many thanks ...
-----Original Message-----
Sent: Thursday, May 21, 2009 5:33 PM
To: Liyu, Andrei V; Jeff Hill; [email protected]
Subject: RE: where is ca_detach_context()?
Jeff,
It looks like you only added the prototype for ca_detach_context to
cadef.h on 2009-02-09, in version 1.77.2.3. But 3.14.10 is 1.77.2.2.
Here is from the CVS log:
corvette:base-3.14.10/src/ca>cvs log cadef.h
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/ca/cadef.h,v
Working file: cadef.h
head: 1.81
branch:
locks: strict
access list:
symbolic names:
R3-14-10: 1.77.2.2
revision 1.77.2.4
date: 2009-04-27 18:31:50 +0000; author: anj; state: Exp; lines: +1
-120; commitid: Q3pBeryDyMfoxGLt;
More ANSI C conversion
revision 1.77.2.3
date: 2009-02-09 15:23:06 +0000; author: jhill; state: Exp; lines: +1
-0; commitid: QMXGzjgPlK56YLBt;
addred proto for ca_detach_context
revision 1.77.2.2
date: 2004-10-19 20:21:31 +0000; author: jhill; state: Exp; lines: +1
-1;
ca_get_host_name() used to return void, but has been changed to
return the string length.
From: [email protected] on behalf of Liyu, Andrei V
Sent: Thu 5/21/2009 6:01 PM
To: Jeff Hill; [email protected]
Jeff hi,
Compiler is not a issue because header file doesn't have
ca_detach_context() function.
I again have loaded baseR3.14.10.tar.gz file (date is October 27, 2008)
from Epics cite
In ...\src\ca\cadeh.h
>From line 115 (you mentioned about line 119)
typedef struct event_handler_args {
void *usr; /* user argument supplied with request */
chanId chid; /* channel id */
long type; /* the type of the item returned */
long count; /* the element count of the item returned */
READONLY void *dbr; /* a pointer to the item returned */
int status; /* ECA_XXX status of the requested op from
the server */
} evargs;
>From line 874
* used when an auxillary thread needs to join a CA client context
started
* by another thread
epicsShareFunc struct ca_client_context * epicsShareAPI
ca_current_context ();
epicsShareFunc int epicsShareAPI ca_attach_context ( struct
ca_client_context * context );
epicsShareFunc int epicsShareAPI ca_client_status ( unsigned level );
epicsShareFunc int epicsShareAPI ca_context_status ( struct
ca_client_context *, unsigned level );
I don't see line with epicsShareFunc void epicsShareAPI
ca_detach_context ();
Maybe somebody load baseR3.14.10.tar.gz (date is October 27, 2008) and
check also.
Thanks, Andrei.
Sent: Thursday, May 21, 2009 2:32 PM
To: Liyu, Andrei V; [email protected]
Hi Andrei,
You should see the function prototype, as follows, at about line number
189 in cadef.h.
"epicsShareFunc void epicsShareAPI ca_detach_context ();"
I see it also at ordinal 119 with symbol name "_ca_detach_context@0"
when I run the ms depends.exe tool, and load ca.dll.
I am looking at the very latest version of R3.14, but I don't expect
that any of this has changed in the patch releases.
> I can't use ca_detach_context () in my program because
> compiler doesn't find this function.
Are you using the MS compiler? Perhaps you need to specify /MD to enable
linking with multithreaded DLL runtime libraries.
Typical Windows MS Build Options
cl -c /nologo /D__STDC__=0 /Ox /GL /W3 /w44355 /MD -I. -I..
-I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\acctst.c
link -nologo /LTCG /incremental:no /opt:ref /release /version:3.14
-out:acctst.exe acctstMain.obj acctst.obj
d:/user/R3.14.clean/epics/base/lib/WIN32-x86/ca.lib
In summary, the following code runs in the preprocess in shareLib.h when
it's a windows compilation. As I recall, _DLL is defined by windows
compilers when /MD (or the equivalent with a 3rd party compiler) is
specified.
# if defined(_DLL) /* this indicates that we are being compiled to
call DLLs */
# define epicsShareExtern __declspec(dllimport) extern
# define epicsShareClass __declspec(dllimport)
# define epicsShareFunc __declspec(dllimport)
# else
# define epicsShareExtern extern
# endif
Jeff
[mailto:[email protected]] On Behalf Of Liyu, Andrei V
Sent: Thursday, May 21, 2009 2:56 PM
To: [email protected]
Subject: where is ca_detach_context()?
I need to write simple CA client with couple threads. Both threads use
CA. So I need to use ca_attach_context() and ca_detach_context() in
second thread.
I can't use ca_detach_context () in my program because compiler doesn't
find this function.
I checked manually and couldn't find "ca_detach_context" in cadef.h and
ca.dll files.
I do found "ca_detach_context" in access.cpp and CAref.html have it.
What is wrong?
I try to use Epics versions 3.14.9 and 3.14.10.
Thanks, Andrei.
- Re: where is ca_detach_context()? Andrew Johnson
- where is ca_detach_context()? Liyu, Andrei V
- RE: where is ca_detach_context()? Jeff Hill
- RE: where is ca_detach_context()? Liyu, Andrei V
- RE: where is ca_detach_context()? Mark Rivers
R3.14.9 access security and "no read access" w/caget John A. Priller
Re: R3.14.9 access security and "no read access" w/caget Andrew Johnson
<2009>
2025
2026
<2009>
2025
2026
