Hi Hinko,
From a quick look at the camonitor code it seems to be using a
low-level element count derived from channel access activity for its
printout. For a generic client of this sort such an approach is reasonable.
I think you should use MALM of 2. This should work and would reduce the
trailing zero count
Carl
Hinko Kocevar wrote:
I'm testing the outputs with the camonitor utility supplied with the
EPICS base.
Hinko
Carl Lionberger
Control System Software Engineer
Berkeley National Laboratory (LBNL)
(510) 486-7503
- Re: subArray processing Hinko Kocevar
- subArray processing Hinko Kocevar
- Re: subArray processing Carl Lionberger
Re: Converting DEC to HEX Tim Mooney
Motor Record OMSL field Ron Sluiter
<2009>
2025
2026
<2009>
2025
2026
