Carl Lionberger wrote:
> Hi Hinko,
> From a quick look at the camonitor code it seems to be using a low-level
> element count derived from channel access activity for its printout. For
> a generic client of this sort such an approach is reasonable.
> I think you should use MALM of 2. This should work and would reduce the
> trailing zero count
Ok, this works as you pointed out, the number of trailing zeros is
reduced to 1.
I'm not sure what our end users will use instead of camonitor and how it
handles the subArray..
Thank you,
Hinko
Hinko Kocevar
Technical support engineer
Instrumentation Technologies
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
- subArray processing Hinko Kocevar
- Re: subArray processing Carl Lionberger
- Re: subArray processing Hinko Kocevar
Plotting array of data in striptool Prachi Chitnis
Re: catools for cross compiled target Hinko Kocevar
<2009>
2025
2026
LabView shared memory interface Kevin Tsubota
<2009>
2025
2026
