At DLS we are currently attempting to reduce our PV
archiving load. Some of the data that we archive is effectively noise, so we are
setting up the use of ADEL wherever possible.
The current version of the motor record doesn't have an
ADEL field, which means that if we set an archive monitor on RBV (the motor
controller readback value) then we archive every change of RBV, including
encoder noise or insignificant servo motor changes.
Would anyone have a problem with me adding ADEL to the
motor record? The default value for ADEL would be zero, so that no change in
default behaviour is seen. But it can then be set to a sensible value for
archiving.
I would implement it in the same way as it's done for the
analogue input record. So this means an additional ALST field for use in the
monitor() function.
While I'm at it I could also add an MDEL field to enable a
value monitor deadband.
Cheers,
Matthew
DLS controls
| ANJ, 31 Jan 2014 |
Home
News
About
Talk
Base
Modules
Extensions
