Hello Matthew,
These seem like good enhancements to me.
Ron
Pearson, MR (Matthew) wrote:
At DLS we are currently attempting to reduce our PV archiving load.
Some of the data that we archive is effectively noise, so we are
setting up the use of ADEL wherever possible.
The current version of the motor record doesn't have an ADEL field,
which means that if we set an archive monitor on RBV (the motor
controller readback value) then we archive every change of RBV,
including encoder noise or insignificant servo motor changes.
Would anyone have a problem with me adding ADEL to the motor record?
The default value for ADEL would be zero, so that no change in default
behaviour is seen. But it can then be set to a sensible value for
archiving.
I would implement it in the same way as it's done for the analogue
input record. So this means an additional ALST field for use in the
monitor() function.
While I'm at it I could also add an MDEL field to enable a value
monitor deadband.
Cheers,
Matthew
DLS controls
This e-mail and any attachments may contain confidential, copyright
and or privileged material, and are for the use of the intended
addressee only. If you are not the intended addressee or an authorised
recipient of the addressee please notify us of receipt by returning
the e-mail and do not use, copy, retain, distribute or disclose the
information in or attached to the e-mail.
Any opinions expressed within this e-mail are those of the individual
and not necessarily of Diamond Light Source Ltd.
Diamond Light Source Ltd. cannot guarantee that this e-mail or any
attachments are free from viruses and we cannot accept liability for
any damage which you may sustain as a result of software viruses which
may be transmitted in or with the message.
Diamond Light Source Limited (company no. 4375679). Registered in
England and Wales with its registered office at Diamond House, Harwell
Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United
Kingdom
- ASYN Connection feedback Mathew Hicks
- ADEL field in motor record Pearson, MR (Matthew)
RE: Vdct and autosave's info field Alarcon, Arturo
<2009>
2025
2026
ca examples Patrick Thomas
<2009>
2025
2026
ANJ, 31 Jan 2014 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
