1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Vdct and autosave's info field
To: "Andrew Johnson" <[email protected]>, <[email protected]>
Date: Wed, 10 Jun 2009 15:42:44 -0700
Cosylab has upgraded VDCT, starting with v2.6, so that the info field is kept after resaving a VDCT file, using VDCT, that has info fields included.
arturo
-----Original Message-----
Sent: Tuesday, January 13, 2009 8:20 AM
To: [email protected]
Cc: Tim Mooney; Alarcon, Arturo
Subject: Re: Vdct and autosave's info field
On Tuesday 13 January 2009 09:01:03 Tim Mooney wrote:
> Autosave (v 4.3 and later) does already permit info nodes to specify
> the fields that are to be autosaved.  However, I have not found a way
> to make vdct leave these fields in a database.
This doesn't solve the issue with vdct remembering info data (the ability to do so will have to be coded into vdct; if someone needs this and is willing to pay for it, I'm sure CosyLab will be happy to oblige), but you can at least put the info data into a separate file.db that just contains entries like these:
record(type,name) {
  info(key,value)
It wouldn't be hard to write a tool to pull just these items out of an existing .db file into a separate file; ask me if it would help and I'll see what I can do.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Vdct and autosave's info field Alarcon, Arturo
Re: Vdct and autosave's info field Tim Mooney
Re: Vdct and autosave's info field Andrew Johnson
Prev: Re: ADEL field in motor record Ron Sluiter
Next: ca examples Patrick Thomas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Vdct and autosave's info field Thompson, David H.
Next: Newport ESP300 on Linux Patrick Thomas
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
