I have been using comments like this for some time:
# @req $(S)_$(SS):Gate$(N)_$(DI):SubRevDlySet
# @arReq $(S)_$(SS):Gate$(N)_$(DI):SubRevDlySet 3600 Monitor
record(longout, "$(S)_$(SS):Gate$(N)_$(DI):SubRevDlySet") {
field(DESC, "Sub-Revolution Delay").....
These are super easy to pull out of the expanded db file with sed. VDCT
preserves comments with the records. With a supporting make target in
the RULES file it becomes reasonably transparent. Not elegant but
functional.
I don't maintain most of the IOCs where this PV lives so I have to do as
much as I can to help the IOC engineers if I want the timing PVs
restored.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Tuesday, January 13, 2009 11:20 AM
To: [email protected]
Cc: Alarcon, Arturo
Subject: Re: Vdct and autosave's info field
On Tuesday 13 January 2009 09:01:03 Tim Mooney wrote:
> Autosave (v 4.3 and later) does already permit info nodes to specify
the
> fields that are to be autosaved. However, I have not found a way to
> make vdct leave these fields in a database.
This doesn't solve the issue with vdct remembering info data (the
ability to
do so will have to be coded into vdct; if someone needs this and is
willing
to pay for it, I'm sure CosyLab will be happy to oblige), but you can at
least put the info data into a separate file.db that just contains
entries
like these:
record(type,name) {
info(key,value)
It wouldn't be hard to write a tool to pull just these items out of an
existing .db file into a separate file; ask me if it would help and I'll
see
what I can do.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
- Vdct and autosave's info field Alarcon, Arturo
- Re: Vdct and autosave's info field Tim Mooney
- Re: Vdct and autosave's info field Andrew Johnson
RE: Schneider Electric - BMXP342020 - CPU340-20 Mark Rivers
RE: CA.DLL for Windows ? Mark Rivers
<2009>
2025
2026
RE: Vdct and autosave's info field Alarcon, Arturo
<2009>
2025
2026
