On Tuesday 13 January 2009 09:01:03 Tim Mooney wrote:
> Autosave (v 4.3 and later) does already permit info nodes to specify the
> fields that are to be autosaved. However, I have not found a way to
> make vdct leave these fields in a database.
This doesn't solve the issue with vdct remembering info data (the ability to
do so will have to be coded into vdct; if someone needs this and is willing
to pay for it, I'm sure CosyLab will be happy to oblige), but you can at
least put the info data into a separate file.db that just contains entries
like these:
record(type,name) {
info(key,value)
It wouldn't be hard to write a tool to pull just these items out of an
existing .db file into a separate file; ask me if it would help and I'll see
what I can do.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
- RE: Vdct and autosave's info field Thompson, David H.
- RE: Vdct and autosave's info field Alarcon, Arturo
- Vdct and autosave's info field Alarcon, Arturo
- Re: Vdct and autosave's info field Tim Mooney
Re: Newport ESP300 on Linux Ron Sluiter
Re: webca can't connect to pvs? Andrew Johnson
<2009>
2025
2026
<2009>
2025
2026
