Hi Matthew,
On Friday 10 July 2009 04:22:35 Pearson, MR (Matthew) wrote:
> What is the recommended way to install POSIX signal handlers in Epics?
> What I want to do is handle SIGINT and SIGTERM signals, and to perform
> some shutdown tasks before the process terminates. Is there is an Epics
> OSI method I can use? Otherwise I will just use the normal POSIX
> methods.
No, there would be little point in just wrapping the Posix APIs since the
underlying mechanisms might be rather different on an OS that doesn't provide
those.
On architectures that support Posix signals we install handlers for SIGHUP and
SIGPIPE, and for SIGALRM up to R3.14.10 (but that interferes with the
implementation of the Posix timers API on Linux which is why we're dropping
it in R3.14.11). Our code is in base/src/libCom/osi/os/posix/osdSignal.cpp
but I would caution you against directly copying what we do because we
register a single argument sa_handler whereas you might prefer to use a 3
argument sa_sigaction handler instead.
> This is for a linux device driver. It's unlikely that the driver will be
> portable to other platforms (because it relies on a manufacturer Linux
> only SDK). So I'm only asking for good-practice reasons, rather than
> portability reasons.
Good practice would be just to follow the Posix and Linux standards.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
- POSIX signals in Epics Pearson, MR (Matthew)
RE: [APS Beamline_controls] Access to IO registers from user-spacein recent Linux versions Mark Rivers
<2009>
2025
2026
DB CA link to PROC field Benjamin Franksen
<2009>
2025
2026
