1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: cainfo does display host info
To: Jeff Hill <[email protected]>
Cc: [email protected]
Date: Wed, 22 Jul 2009 08:22:45 -0700
Hi Jeff,
That does not work for me.
Only when I turn on "nscd" on my linux systems do things work reliably.
When nscd is not running most of the time I get the empty string.
Ernest
Jeff Hill wrote:
Dirk,
I think the IP address would be better than an empty string.
TBOMK, it does return the dotted IP address as a string if the DNS transaction hasn't completed yet. Let me know if that isn’t the case.
unsigned hostNameCache::getName ( char * pBuf, unsigned bufSize ) const
    if ( bufSize == 0u ) {
        return 0u;
    epicsGuard < epicsMutex > guard ( this->mutex );
    if ( this->nameLength > 0u ) {
        if ( this->nameLength < bufSize ) {
            strcpy ( pBuf, this->hostNameBuf );
            return this->nameLength;
        else {
            unsigned reducedSize = bufSize - 1u;
            strncpy ( pBuf, this->hostNameBuf, reducedSize );
            pBuf [ reducedSize ] = '\0';
            return reducedSize;
    else {
        osiSockAddr tmpAddr = this->dnsTransaction.address ();
        return sockAddrToDottedIP ( &tmpAddr.sa, pBuf, bufSize );
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
-----Original Message-----
Sent: Wednesday, July 22, 2009 12:46 AM
To: Jeff Hill
Jeff Hill wrote:
I'm fully open to alternative suggestions.
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
RE: cainfo does display host info Jeff Hill
cainfo does display host info Carl Schumann
Re: cainfo does display host info Dirk Zimoch
Re: cainfo does display host info Ralph Lange
Prev: RE: cainfo does display host info Jeff Hill
Next: Re: cainfo does display host info Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: cainfo does display host info Jeff Hill
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
