1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: cainfo does display host info
To: "'Ernest L. Williams Jr.'" <[email protected]>
Cc: [email protected]
Date: Wed, 22 Jul 2009 09:30:52 -0600
> That does not work for me.
> Only when I turn on "nscd" on my linux systems do things work reliably.
> When nscd is not running most of the time I get the empty string.
I created entry 353 in the Mantis bug tracking system.
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
> -----Original Message-----
> From: Ernest L. Williams Jr. [mailto:[email protected]]
> Sent: Wednesday, July 22, 2009 9:23 AM
> To: Jeff Hill
> Cc: 'Dirk Zimoch'; [email protected]
> Subject: Re: cainfo does display host info
> Hi Jeff,
> Thanks,
> Ernest
> Jeff Hill wrote:
> > Dirk,
> >> I think the IP address would be better than an empty string.
> > TBOMK, it does return the dotted IP address as a string if the DNS
> transaction hasn't completed yet. Let me know if that isn’t the case.
> > unsigned hostNameCache::getName (
> >     char * pBuf, unsigned bufSize ) const
> >     if ( bufSize == 0u ) {
> >         return 0u;
> >     epicsGuard < epicsMutex > guard ( this->mutex );
> >     if ( this->nameLength > 0u ) {
> >         if ( this->nameLength < bufSize ) {
> >             strcpy ( pBuf, this->hostNameBuf );
> >             return this->nameLength;
> >         else {
> >             unsigned reducedSize = bufSize - 1u;
> >             strncpy ( pBuf, this->hostNameBuf, reducedSize );
> >             pBuf [ reducedSize ] = '\0';
> >             return reducedSize;
> >     else {
> >         osiSockAddr tmpAddr = this->dnsTransaction.address ();
> >         return sockAddrToDottedIP ( &tmpAddr.sa, pBuf, bufSize );
> > Jeff
> >> From: Dirk Zimoch [mailto:[email protected]]
> >> Sent: Wednesday, July 22, 2009 12:46 AM
> >> To: Jeff Hill
> >> Jeff Hill wrote:
> >>> I'm fully open to alternative suggestions.
> >> Dr. Dirk Zimoch
> >> Paul Scherrer Institut, WBGB/006
> >> 5232 Villigen PSI, Switzerland
> >> Phone +41 56 310 5182
cainfo does display host info Carl Schumann
Re: cainfo does display host info Dirk Zimoch
Re: cainfo does display host info Ralph Lange
RE: cainfo does display host info Jeff Hill
Re: cainfo does display host info Ernest L. Williams Jr.
Prev: Re: cainfo does display host info Andrew Johnson
Next: Waveform record updating problem Prachi Chitnis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: cainfo does display host info Ernest L. Williams Jr.
Next: Re: cainfo does display host info Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
