1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Building ASYN on Windows
To: "Mark Rivers" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Mon, 10 Aug 2009 15:32:51 -0400 (EDT)
> So that's interesting, if you manually type the command it works, but if
> it is run as part of the "make" build process it fails?
> What version of "make" were you running, i.e. where did you get it?
> Mark
Sorry, I thought I had included that info.
I am using Make from GnuWin32, download from
http://gnuwin32.sourceforge.net/packages.html
John
> -----Original Message-----
> From: John Dobbins [mailto:[email protected]]
> Sent: Monday, August 10, 2009 2:20 PM
> To: Mark Rivers
> Cc: EPICS Tech-Talk
>> John,
>> The error you get with the VC++ compiler is:
>> "Installing created file ../../../bin/win32-x86/genApps.exe"
>> ../../../bin/win32-x86/genApps.exe ../O.Common/gddApps.h
>> make[3]: *** [../O.Common/gddApps.h] Error -1073741819
>> Does O.Common/gddApps.h exist?
> No.
>> What happens if you go the O.win32-x86 directory being built there and
>> just manually type the same command:
> gddApps.h is create (appended a end of message)
>> Do you get an error?
> No
>> The error code you are getting is -1073741819, which is 0xC0000005.
>> That is an access violation on Windows.
>> I don't think this is your problem, but are you running the version of
>> GNU make that works with EPICS 3.14.x?  The version that comes with
>> Cygwin does not work, even though it also has the version number 3.81.
>> The 3.14.10 release notes discuss this under the section on Cygwin
>> builds:
>> "The cygwin make version 3.81-1 does not handle MS-DOS path names and
>> thus does not work for EPICS builds with RELEASE file definitions.
> From
>> the discussion on the cygwin mailing list it looks like this will be
>> fixed in make version 3.82. In the meantime make version 3.80 or a
> fixed
>> make can be downloaded from this website."
> I can install Cygwyn and the modified version of Make.
>> From: [email protected]
>> [mailto:[email protected]] On Behalf Of John Dobbins
>> Sent: Monday, August 10, 2009 11:40 AM
>> To: EPICS Tech-Talk
>> All,
>> I wrote previously:
>> I tried to build 3.14.10 base on WindowsXP Professional 2002 SP 3 with
>> SHARED_LIBRARIES=NO and STATIC_BUILD=YES
>> but get an error. I am able to build 3.14.9 with these options and the
>> same tools.
>> link -nologo  /LTCG /incremental:no /opt:ref /release /version:3.14
>> -out:genApps.exe   genApps.obj gdd.obj gddTest.obj gddAppTable.obj
>> gddNewDel.obj gddAppDefs.obj aitTypes.obj aitConvert.obj
> aitHelpers.obj
>> gddArray.obj gddContainer.obj gddErrorCodes.obj gddUtils.obj
>> gddEnumStringTable.obj    ../../../lib/win32-x86/Com.lib ws2_32.lib
>> ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
>> Generating code
>> Finished generating code
>> make[3]: Leaving directory
>> `W:/winDev/epics/R3.14.10/support/base/src/gdd/O.win3
>> 2-x86'
>> make[2]: *** [install.win32-x86] Error 2
>> make[2]: Leaving directory
>> `W:/winDev/epics/R3.14.10/support/base/src/gdd' make[1]: ***
>> [gdd.install] Error 2
>> make[1]: Leaving directory `W:/winDev/epics/R3.14.10/support/base/src'
>> make: *** [src.install] Error 2
>> Since then I have built R3.14.10 with
>> on two of my home computers, Windows XP Home Edition 2002 SP 3, in one
>> case using MinGW and in the other case Microsoft Visual C++ 2008
> Express
>> Edition, however I remain unable  to do this on our lab computers.
>> On our lab computers I have tried
>> Microsoft Visual C++ 2005, Perl 5.10, Gnu Make 3.81
>> and
>> MinGW, Perl 5.10, Gnu Make 3.81
>> The R3.14.10 Visual C++ build fails when executing the created file
>> genApps.exe.
>> The MinGW build fails when executing the created file dBToMenuH.exe
>> I am including the full output from both builds below, which includes
>> some warnings.
>> Any advice on how to proceed from this point would be welcome.
>> My eventual goal is to run the latest version on areaDetector on
> Windows
>> hence the desire for R3.14.10. Mark Rivers has recommended the
>> STATIC_BUILD for ease of relocating executables.
>> Thanks,
>> John Dobbins
>> environment variables:
>> INCLUDE = C:\Program Files\Microsoft Visual Studio
>> 8\VC\PlatformSDK\include;C:\Program Files\Microsoft Visual Studio
>> 8\VC\include
>> LIB = C:\Program Files\Microsoft Visual Studio 8\VC\lib;C:\Program
>> Files\Microsoft Visual Studio 8\VC\PlatformSDK\Lib
> gddApps.h
> #define gddAppType_status	1
> #define gddAppType_severity	2
> #define gddAppType_timeStamp	3
> #define gddAppType_name	4
> #define gddAppType_class	5
> #define gddAppType_precision	6
> #define gddAppType_graphicHigh	7
> #define gddAppType_graphicLow	8
> #define gddAppType_controlHigh	9
> #define gddAppType_controlLow	10
> #define gddAppType_alarmHigh	11
> #define gddAppType_alarmLow	12
> #define gddAppType_alarmHighWarning	13
> #define gddAppType_alarmLowWarning	14
> #define gddAppType_maxElements	15
> #define gddAppType_value	16
> #define gddAppType_enums	17
> #define gddAppType_units	18
> #define gddAppTypeIndex_units 0
> #define gddAppType_ackt	19
> #define gddAppType_acks	20
> #define gddAppType_attributes	21
> #define gddAppTypeIndex_attributes 0
> #define gddAppTypeIndex_attributes_maxElements 1
> #define gddAppTypeIndex_attributes_units 2
> #define gddAppTypeIndex_attributes_alarmLowWarning 3
> #define gddAppTypeIndex_attributes_alarmHighWarning 4
> #define gddAppTypeIndex_attributes_alarmLow 5
> #define gddAppTypeIndex_attributes_alarmHigh 6
> #define gddAppTypeIndex_attributes_controlLow 7
> #define gddAppTypeIndex_attributes_controlHigh 8
> #define gddAppTypeIndex_attributes_graphicLow 9
> #define gddAppTypeIndex_attributes_graphicHigh 10
> #define gddAppTypeIndex_attributes_precision 11
> #define gddAppType_all	22
> #define gddAppTypeIndex_all 0
> #define gddAppTypeIndex_all_value 1
> #define gddAppTypeIndex_all_units 2
> #define gddAppTypeIndex_all_alarmLowWarning 3
> #define gddAppTypeIndex_all_alarmHighWarning 4
> #define gddAppTypeIndex_all_alarmLow 5
> #define gddAppTypeIndex_all_alarmHigh 6
> #define gddAppTypeIndex_all_controlLow 7
> #define gddAppTypeIndex_all_controlHigh 8
> #define gddAppTypeIndex_all_graphicLow 9
> #define gddAppTypeIndex_all_graphicHigh 10
> #define gddAppTypeIndex_all_precision 11
> #define gddAppType_dbr_gr_short	23
> #define gddAppTypeIndex_dbr_gr_short 0
> #define gddAppTypeIndex_dbr_gr_short_units 1
> #define gddAppTypeIndex_dbr_gr_short_alarmLowWarning 2
> #define gddAppTypeIndex_dbr_gr_short_alarmHighWarning 3
> #define gddAppTypeIndex_dbr_gr_short_alarmLow 4
> #define gddAppTypeIndex_dbr_gr_short_alarmHigh 5
> #define gddAppTypeIndex_dbr_gr_short_graphicLow 6
> #define gddAppTypeIndex_dbr_gr_short_graphicHigh 7
> #define gddAppTypeIndex_dbr_gr_short_value 8
> #define gddAppType_dbr_gr_float	24
> #define gddAppTypeIndex_dbr_gr_float 0
> #define gddAppTypeIndex_dbr_gr_float_units 1
> #define gddAppTypeIndex_dbr_gr_float_alarmLowWarning 2
> #define gddAppTypeIndex_dbr_gr_float_alarmHighWarning 3
> #define gddAppTypeIndex_dbr_gr_float_alarmLow 4
> #define gddAppTypeIndex_dbr_gr_float_alarmHigh 5
> #define gddAppTypeIndex_dbr_gr_float_graphicLow 6
> #define gddAppTypeIndex_dbr_gr_float_graphicHigh 7
> #define gddAppTypeIndex_dbr_gr_float_precision 8
> #define gddAppTypeIndex_dbr_gr_float_value 9
> #define gddAppType_dbr_gr_enum	25
> #define gddAppTypeIndex_dbr_gr_enum 0
> #define gddAppTypeIndex_dbr_gr_enum_value 1
> #define gddAppTypeIndex_dbr_gr_enum_enums 2
> #define gddAppType_dbr_gr_char	26
> #define gddAppTypeIndex_dbr_gr_char 0
> #define gddAppTypeIndex_dbr_gr_char_units 1
> #define gddAppTypeIndex_dbr_gr_char_alarmLowWarning 2
> #define gddAppTypeIndex_dbr_gr_char_alarmHighWarning 3
> #define gddAppTypeIndex_dbr_gr_char_alarmLow 4
> #define gddAppTypeIndex_dbr_gr_char_alarmHigh 5
> #define gddAppTypeIndex_dbr_gr_char_graphicLow 6
> #define gddAppTypeIndex_dbr_gr_char_graphicHigh 7
> #define gddAppTypeIndex_dbr_gr_char_value 8
> #define gddAppType_dbr_gr_long	27
> #define gddAppTypeIndex_dbr_gr_long 0
> #define gddAppTypeIndex_dbr_gr_long_units 1
> #define gddAppTypeIndex_dbr_gr_long_alarmLowWarning 2
> #define gddAppTypeIndex_dbr_gr_long_alarmHighWarning 3
> #define gddAppTypeIndex_dbr_gr_long_alarmLow 4
> #define gddAppTypeIndex_dbr_gr_long_alarmHigh 5
> #define gddAppTypeIndex_dbr_gr_long_graphicLow 6
> #define gddAppTypeIndex_dbr_gr_long_graphicHigh 7
> #define gddAppTypeIndex_dbr_gr_long_value 8
> #define gddAppType_dbr_gr_double	28
> #define gddAppTypeIndex_dbr_gr_double 0
> #define gddAppTypeIndex_dbr_gr_double_units 1
> #define gddAppTypeIndex_dbr_gr_double_alarmLowWarning 2
> #define gddAppTypeIndex_dbr_gr_double_alarmHighWarning 3
> #define gddAppTypeIndex_dbr_gr_double_alarmLow 4
> #define gddAppTypeIndex_dbr_gr_double_alarmHigh 5
> #define gddAppTypeIndex_dbr_gr_double_graphicLow 6
> #define gddAppTypeIndex_dbr_gr_double_graphicHigh 7
> #define gddAppTypeIndex_dbr_gr_double_precision 8
> #define gddAppTypeIndex_dbr_gr_double_value 9
> #define gddAppType_dbr_ctrl_short	29
> #define gddAppTypeIndex_dbr_ctrl_short 0
> #define gddAppTypeIndex_dbr_ctrl_short_units 1
> #define gddAppTypeIndex_dbr_ctrl_short_alarmLowWarning 2
> #define gddAppTypeIndex_dbr_ctrl_short_alarmHighWarning 3
> #define gddAppTypeIndex_dbr_ctrl_short_alarmLow 4
> #define gddAppTypeIndex_dbr_ctrl_short_alarmHigh 5
> #define gddAppTypeIndex_dbr_ctrl_short_controlLow 6
> #define gddAppTypeIndex_dbr_ctrl_short_controlHigh 7
> #define gddAppTypeIndex_dbr_ctrl_short_graphicLow 8
> #define gddAppTypeIndex_dbr_ctrl_short_graphicHigh 9
> #define gddAppTypeIndex_dbr_ctrl_short_value 10
> #define gddAppType_dbr_ctrl_float	30
> #define gddAppTypeIndex_dbr_ctrl_float 0
> #define gddAppTypeIndex_dbr_ctrl_float_units 1
> #define gddAppTypeIndex_dbr_ctrl_float_alarmLowWarning 2
> #define gddAppTypeIndex_dbr_ctrl_float_alarmHighWarning 3
> #define gddAppTypeIndex_dbr_ctrl_float_alarmLow 4
> #define gddAppTypeIndex_dbr_ctrl_float_alarmHigh 5
> #define gddAppTypeIndex_dbr_ctrl_float_controlLow 6
> #define gddAppTypeIndex_dbr_ctrl_float_controlHigh 7
> #define gddAppTypeIndex_dbr_ctrl_float_graphicLow 8
> #define gddAppTypeIndex_dbr_ctrl_float_graphicHigh 9
> #define gddAppTypeIndex_dbr_ctrl_float_precision 10
> #define gddAppTypeIndex_dbr_ctrl_float_value 11
> #define gddAppType_dbr_ctrl_enum	31
> #define gddAppTypeIndex_dbr_ctrl_enum 0
> #define gddAppTypeIndex_dbr_ctrl_enum_value 1
> #define gddAppTypeIndex_dbr_ctrl_enum_enums 2
> #define gddAppType_dbr_ctrl_char	32
> #define gddAppTypeIndex_dbr_ctrl_char 0
> #define gddAppTypeIndex_dbr_ctrl_char_units 1
> #define gddAppTypeIndex_dbr_ctrl_char_alarmLowWarning 2
> #define gddAppTypeIndex_dbr_ctrl_char_alarmHighWarning 3
> #define gddAppTypeIndex_dbr_ctrl_char_alarmLow 4
> #define gddAppTypeIndex_dbr_ctrl_char_alarmHigh 5
> #define gddAppTypeIndex_dbr_ctrl_char_controlLow 6
> #define gddAppTypeIndex_dbr_ctrl_char_controlHigh 7
> #define gddAppTypeIndex_dbr_ctrl_char_graphicLow 8
> #define gddAppTypeIndex_dbr_ctrl_char_graphicHigh 9
> #define gddAppTypeIndex_dbr_ctrl_char_value 10
> #define gddAppType_dbr_ctrl_long	33
> #define gddAppTypeIndex_dbr_ctrl_long 0
> #define gddAppTypeIndex_dbr_ctrl_long_units 1
> #define gddAppTypeIndex_dbr_ctrl_long_alarmLowWarning 2
> #define gddAppTypeIndex_dbr_ctrl_long_alarmHighWarning 3
> #define gddAppTypeIndex_dbr_ctrl_long_alarmLow 4
> #define gddAppTypeIndex_dbr_ctrl_long_alarmHigh 5
> #define gddAppTypeIndex_dbr_ctrl_long_controlLow 6
> #define gddAppTypeIndex_dbr_ctrl_long_controlHigh 7
> #define gddAppTypeIndex_dbr_ctrl_long_graphicLow 8
> #define gddAppTypeIndex_dbr_ctrl_long_graphicHigh 9
> #define gddAppTypeIndex_dbr_ctrl_long_value 10
> #define gddAppType_dbr_ctrl_double	34
> #define gddAppTypeIndex_dbr_ctrl_double 0
> #define gddAppTypeIndex_dbr_ctrl_double_units 1
> #define gddAppTypeIndex_dbr_ctrl_double_alarmLowWarning 2
> #define gddAppTypeIndex_dbr_ctrl_double_alarmHighWarning 3
> #define gddAppTypeIndex_dbr_ctrl_double_alarmLow 4
> #define gddAppTypeIndex_dbr_ctrl_double_alarmHigh 5
> #define gddAppTypeIndex_dbr_ctrl_double_controlLow 6
> #define gddAppTypeIndex_dbr_ctrl_double_controlHigh 7
> #define gddAppTypeIndex_dbr_ctrl_double_graphicLow 8
> #define gddAppTypeIndex_dbr_ctrl_double_graphicHigh 9
> #define gddAppTypeIndex_dbr_ctrl_double_precision 10
> #define gddAppTypeIndex_dbr_ctrl_double_value 11
> #define gddAppType_dbr_stsack_string	35
> #define gddAppTypeIndex_dbr_stsack_string 0
> #define gddAppTypeIndex_dbr_stsack_string_ackt 1
> #define gddAppTypeIndex_dbr_stsack_string_acks 2
> #define gddAppTypeIndex_dbr_stsack_string_value 3
Re: Building ASYN on Windows Andrew Johnson
Building ASYN on Windows John Dobbins
RE: Building ASYN on Windows Mark Rivers
RE: Building ASYN on Windows John Dobbins
Prev: Re: Building ASYN on Windows John Dobbins
Next: RE: Building ASYN on Windows Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Building ASYN on Windows Mark Rivers
Next: Re: Building ASYN on Windows Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
