John,
> I tried to pretend nothing was wrong, I ran makeBaseApp.pl for example
app
> and built it successfully, but when I run it I get:
> W:\tmp\example\iocBoot\iocmyExample>..\..\bin\win32-x86\myExample.exe
st.cmd
> epicsThread: Unknown C++ exception in thread "timerQueue" at Mon Aug
10
> 2009 15:03:39.518960139
That error does not have anything to do with your build errors, that is
a known bug in base 3.14.10 on win32-x86.
In the Known Problems file for 3.14.10
(http://www.aps.anl.gov/epics/base/R3-14/10-docs/KnownProblems.html)
you will see this item:
"IOCs or other EPICS programs running on a Win32 system with multiple
CPUs may die at startup. This patch applied to the
base/src/libCom/osi/os/WIN32/osdTime.cpp file solves an issue with time
provider registration on Windows."
Apply that patch to base and it should fix your problem.
-----Original Message-----
[mailto:[email protected]] On Behalf Of John Dobbins
Sent: Monday, August 10, 2009 2:31 PM
To: Andrew Johnson
Cc: [email protected]
Subject: Re: Building ASYN on Windows
> Hi John
> On Monday 10 August 2009 11:39:47 John Dobbins wrote:
>> The R3.14.10 Visual C++ build fails when executing the created file
>> genApps.exe.
>> The MinGW build fails when executing the created file dBToMenuH.exe
> Both of those failures were in programs that were built earlier in the
> process. What is strange though is that those aren't the first
programs
> to
> be run that we built earlier; that honor goes to e_flex.exe and
> antelope.exe
> which are both used when compiling in the base/src/dbStatic directory
and
> which run quite happily on your builds. Indeed for your Visual C++
build
> all
> of the code that you actually need to build IOCs and Mark's
areaDetector
> application have successfully been built by that stage, so you could
> ignore
> the gdd build failure (which is only needed for non-IOC CA servers)
and
> continue on to compile your other modules at this point.
> Question: What was your PATH set to when you were building these? You
> didn't
> have the bin directory from another release of Base or from the EPICS
> Win32
> extensions in the path did you? I would guess not, but I'd like to be
> sure
> of that.
PATH =
C:\Perl\site\bin;C:\Perl\bin;C:\Xilinx\10.1\ISE\bin\nt;C:\Xilinx\10.1\IS
E\lib\nt;C:\Xilinx\10.1\ISE\smartmodel\nt\installed_nt\lib\pcnt.lib;C:\W
INDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\wbem;C:\Program
Files\Hummingbird\Connectivity\11.00\Accessories\;c:\program
files\microsoft sql server\90\tools\binn\;C:\Program
Files\MATLAB\R2006a\bin\win32;C:\Program
Files\Sudowin\Clients\Console;C:\Program
Files\TortoiseSVN\bin;C:\strawberry\c\bin;C:\strawberry\perl\bin;C:\Prog
ram
Files\Agilent\IO Libraries Suite\bin;C:\Program Files\IVI
Foundation\IVI\bin;C:\Program Files\IVI
Foundation\VISA\WinNT\Bin\;C:\Program Files\IVI
Foundation\VISA\winnt\agvisa;C:\Program Files\Microsoft Visual Studio
8\VC\bin;C:\Program Files\Microsoft Visual Studio
8\Common7\IDE;C:\Program
Files\GnuWin32\bin;W:\winDev\epics\R3.14.10\base-3.14.10\bin\win32-x86
>> I am including the full output from both builds below, which includes
>> some warnings.
> At a brief glance through I recognize many of those warnings, which
are
> not
> something that could have caused this problem.
> The interesting thing is that in both cases the same error code
occurs,
> which
> Mark Rivers points out to mean access violation (I'm taking his word
> there).
>> Any advice on how to proceed from this point would be welcome.
> If you still have or can repeat the VC++ build, just use that and
ignore
> the
> build failure in gdd, the parts of Base you need have already built
> correctly
> by then so you can continue to build the other modules. It would be
good
> to
> get to the bottom of this though.
> - Andrew
> The best FOSS code is written to be read by other humans -- Harold
Welte
app
st.cmd
epicsThread: Unknown C++ exception in thread "timerQueue" at Mon Aug 10
2009 15:
03:39.518960139
#!../../bin/win32-x86/myExample
## You may have to change myExample to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","win32-x86")
epicsEnvSet("IOC","iocmyExample")
epicsEnvSet("TOP","W:/tmp/example")
epicsEnvSet("EPICS_BASE","W:/winDev/epics/R3.14.10/base-3.14.10")
cd W:/tmp/example
dbLoadDatabase "dbd/myExample.dbd"
myExample_registerRecordDeviceDriver pdbbase
## Load record instances
dbLoadTemplate "db/userHost.substitutions"
dbLoadRecords "db/dbSubExample.db", "user=erpoprHost"
## Set this to see messages from mySub
#var mySubDebug 1
## Run this to trace the stages of iocInit
#traceIocInit
cd W:/tmp/example/iocBoot/iocmyExample
iocInit
Starting iocInit
## EPICS R3.14.10 $R3-14-10$ $2008/10/27 19:39:04$
## EPICS Base built Aug 10 2009
This application has requested the Runtime to terminate it in an unusual
way. Please contact the application's support team for more information.
## Start any sequence programs
#seq sncExample, "user=erpoprHost"
epics>
At which point I get a Windows dialog to choose debug/send/don't_send
error report.
John
- RE: Building ASYN on Windows John Dobbins
- Building ASYN on Windows John Dobbins
- RE: Building ASYN on Windows Mark Rivers
- Re: Building ASYN on Windows Andrew Johnson
- Re: Building ASYN on Windows John Dobbins
<2009>
2025
2026
<2009>
2025
2026
