1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: anyone seen this error
To: Pierrick Hanlet <[email protected]>
Date: Thu, 20 Aug 2009 13:26:47 +0200
Hi Pierrick,
If your OUT is a CA link (to another IOC) make sure to set EPICS_CA_MAX_ARRAY_BYTES large enough (default is 16k) on both IOCs.
Dirk
Pierrick Hanlet wrote:
I'm using genSubRecord with both input "A" and output "OUTA" fields.
I have the following error:
Link U - Array too large! 1993313664 Bytes
which shows up after iocInit
Starting iocInit
## EPICS R3.14.10 $R3-14-10$ $2008/10/27 19:39:04$
## EPICS Base built May 29 2009
If I comment out the "field(OUTA" line, I don't get this error.  Has anyone ever seen this?
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039 office/lab/fax http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
Re: anyone seen this error Pierrick Hanlet
Prev: anyone seen this error Pierrick Hanlet
Next: Re: VME SBC suggestion? Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: anyone seen this error Pierrick Hanlet
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
