1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VME SBC suggestion?
To: "Ernest L. Williams Jr." <[email protected]>
Cc: Dimitrios Tsifakis <[email protected]>, [email protected]
Date: Thu, 20 Aug 2009 13:35:18 +0200
Hi all,
All redirects don't work, neither "ld < library" nor "< script". The startup script terminates after these redirects. I also found that a "cd" within the startup script is reversed after the script ended.
I use
SHELL_COMPATIBLE TRUE
but SHELL_TASK_OPTIONS has the option VX_PRIVATE_ENV set. Maybe that is the problem. I tried 6.2 and will try 6.7 soon.
Can anyone check these configs:
/* Shell default configuration */
#define SHELL_SECURE		FALSE
#define SHELL_START_AT_BOOT	TRUE
#define SHELL_COMPATIBLE	TRUE
#define SHELL_DEFAULT_CONFIG	\
"LINE_EDIT_MODE=,LINE_LENGTH=256,STRING_FREE=manual,INTERPRETER=,VXE_PATH=.;/romfs"
#define SHELL_FIRST_CONFIG	NULL
#define SHELL_REMOTE_CONFIG	NULL
#define SHELL_TASK_NAME_BASE	"tShell"
#define SHELL_TASK_PRIORITY	1
#define SHELL_TASK_OPTIONS (VX_FP_TASK | VX_UNBREAKABLE | COPROCS_ALL | VX_PRIVATE_ENV)
I am using INCLUDE_SHELL but none of
INCLUDE_SHELL_VI_MODE
INCLUDE_SHELL_EMACS_MODE
INCLUDE_SHELL_INTERP_C
INCLUDE_SHELL_INTERP_CMD
Should I include any of these?
Dirk
Andrew Johnson wrote:
Hi Dirk,
On Wednesday 19 August 2009 05:42:19 Dirk Zimoch wrote:
Generally, vxWorks 6 has some new features (e.g. real time processes) which are not used by EPICS. vxWorks 6 still supports running applications, e.g. EPICS, in "kernel space" (which is all you had in vxWorks 5). However, the vxWorks shell has changed a bit and not everything that worked in vxWorks 5 startup scripts might work in vxWork 6 startup scripts (I had difficulties sourcing other scripts). I think I can tell more once I have the MVME4100
running.
I wonder if your sourcing scripts problem is the the same issue we found when we upgraded to vxWorks 5.5.2 - if you use the construct
    ld < ioc.munch
in your startup script then all subsequent shell redirections to source other scripts get ignored. The solution is to replace the above line with this
    ld 0, 0, "ioc.munch"
which permits later shell source commands to operate normally. I think it's highly likely that Wind River broke both versions of the target shell at the same time...
I am also not having problems with this.
However, in the beginning I bumped into this as well.
We are using vxWorks 6.6 on some projects here at SLAC:
Using the vxWorks project facility please do the following:
vxprj parameter set SHELL_COMPATIBLE TRUE
vxprj parameter set SHELL_TASK_OPTIONS "(VX_FP_TASK | VX_UNBREAKABLE | COPROCS_ALL)" =================================================================================
I had to make similar changes when I was at the SNS as well.
Sorry, I forgot to add you must rebuild your kernel after these changes:
vxprj build
Cheers,
Ernest
Ernest
- Andrew
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
RE: VME SBC suggestion? Williams Jr., Ernest L.
VME SBC suggestion? Dimitrios Tsifakis
Re: VME SBC suggestion? Dimitrios Tsifakis
Re: VME SBC suggestion? Dirk Zimoch
Re: VME SBC suggestion? Andrew Johnson
Re: VME SBC suggestion? Ernest L. Williams Jr.
Prev: Re: anyone seen this error Dirk Zimoch
Next: Re: anyone seen this error Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VME SBC suggestion? Ernest L. Williams Jr.
Next: RE: VME SBC suggestion? Williams Jr., Ernest L.
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
