Hi Dirk,
Thanks for responding.
No, I'm actually running this soft IOC as a simulation for development. It is connected to
an EDM panel from which I'm inputting values to the IOC. However, since I don't have
this environment variable set, I'll do so now.
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039 office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
----- Original Message -----
Date: Thursday, August 20, 2009 6:26 am
Subject: Re: anyone seen this error
To: Pierrick Hanlet <[email protected]>
Cc: "[email protected]" <[email protected]>
> Hi Pierrick,
> If your OUT is a CA link (to another IOC) make sure to set
> EPICS_CA_MAX_ARRAY_BYTES large enough (default is 16k) on both IOCs.
> Dirk
> Pierrick Hanlet wrote:
> > Hi,
> > I'm using genSubRecord with both input "A" and output "OUTA" fields.
> > I have the following error:
> > Link U - Array too large! 1993313664 Bytes
> > which shows up after
> > iocInit
> > Starting iocInit
> > ## EPICS R3.14.10 $R3-14-10$ $2008/10/27 19:39:04$
> > ## EPICS Base built May 29 2009
> > If I comment out the "field(OUTA" line, I don't get this error. Has
> anyone ever seen this?
> > Thanks,
> > Pierrick
> > Pierrick Hanlet
> > Batavia, IL 60510
> > [email protected]
> Dr. Dirk Zimoch
> Paul Scherrer Institut, WBGB/006
> 5232 Villigen PSI, Switzerland
> Phone +41 56 310 5182
- Re: anyone seen this error Andrew Johnson
- anyone seen this error Pierrick Hanlet
- Re: anyone seen this error Dirk Zimoch
Re: VME SBC suggestion? Dirk Zimoch
RE: VME SBC suggestion? Williams Jr., Ernest L.
<2009>
2025
2026
<2009>
2025
2026
