1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem building EPICS base 3.14.11
To: EPICS Talk Tech <[email protected]>
Date: Wed, 2 Sep 2009 22:05:27 +1000
The following message appears when building EPICS base 3.14.11 with INSTALL_LOCATION=<some_path_different_to_top> in configure/ CONFIG_SITE. This problem appears in darwin-x86 (MacBook Pro) and linux-x86 (Linux debian etch). In this case, TOP=/opt/epics/3.14.11/ base and INSTALL_LOCATION=/opt/epics/3.14.11/install
$ cd /opt/epics/3.14.11/base
$ make
make -C ./softIoc install
perl /opt/epics/3.14.11/install/bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../../..
mkdir O.Common
make -C O.darwin-x86 -f ../Makefile TOP=../../.. T_A=darwin-x86 install
perl /opt/epics/3.14.11/install/bin/darwin-x86/makeIncludeDbd.pl base.dbd dlload.dbd system.dbd ../O.Common/softIocInclude.dbd
Expanding dbd
/opt/epics/3.14.11/install/bin/darwin-x86/dbExpand -I . -I .. -I /opt/ epics/3.14.11/install/dbd -o ../O.Common/softIoc.dbd ../O.Common/ softIocInclude.dbd
Installing created dbd file /opt/epics/3.14.11/install/dbd/softIoc.dbd
Installing db file /opt/epics/3.14.11/install/db/softIocExit.db
mkdir /opt/epics/3.14.11/install/db
perl ../makeInstallDir.pl /opt/epics/3.14.11/install > ../O.Common/ epicsInstallDir.h Can't locate EPICS/Path.pm in @INC (@INC contains: /opt/epics/3.14.11/ base/src/softIoc/../../lib/perl /Library/Perl/Updates/5.8.8 /System/ Library/Perl/5.8.8/darwin-thread-multi-2level /System/Library/Perl/ 5.8.8 /Library/Perl/5.8.8/darwin-thread-multi-2level /Library/Perl/ 5.8.8 /Library/Perl /Network/Library/Perl/5.8.8/darwin-thread- multi-2level /Network/Library/Perl/5.8.8 /Network/Library/Perl /System/ Library/Perl/Extras/5.8.8/darwin-thread-multi-2level /System/Library/ Perl/Extras/5.8.8 /Library/Perl/5.8.6 /Library/Perl/5.8.1 .) at ../ makeInstallDir.pl line 15.
BEGIN failed--compilation aborted at ../makeInstallDir.pl line 15.
make[3]: *** [../O.Common/epicsInstallDir.h] Error 2
make[2]: *** [install.darwin-x86] Error 2
make[1]: *** [softIoc.install] Error 2
make: *** [src.install] Error 2
Any help will be appreciated. Thank you.
  Juan Carlos.
Juan Carlos Guzman
Software Engineer
CSIRO Australia Telescope National Facility (ATNF)
P.O.Box 76, Epping NSW 1710, Australia
Phone: +61 2 9372 4457
Fax: +61 2 9372 4310
Email: [email protected]
Re: Problem building EPICS base 3.14.11 Andrew Johnson
Prev: aSub vs. genSub - Documentation? Dr. Peter Zumbruch
Next: Re: aSub vs. genSub - Documentation? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: aSub vs. genSub - Documentation? Andrew Johnson
Next: Re: Problem building EPICS base 3.14.11 Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
