Hi Juan Carlos,
On Wednesday 02 September 2009 07:05:27 Juan Carlos Guzman wrote:
> The following message appears when building EPICS base 3.14.11 with
> INSTALL_LOCATION=<some_path_different_to_top> in configure/
> CONFIG_SITE. This problem appears in darwin-x86 (MacBook Pro) and
> linux-x86 (Linux debian etch). In this case, TOP=/opt/epics/3.14.11/
> base and INSTALL_LOCATION=/opt/epics/3.14.11/install
> perl ../makeInstallDir.pl /opt/epics/3.14.11/install > ../O.Common/
> epicsInstallDir.h
> Can't locate EPICS/Path.pm in @INC (@INC contains: /opt/epics/3.14.11/
> base/src/softIoc/../../lib/perl /Library/Perl/Updates/5.8.8 /System/
> Library/Perl/5.8.8/darwin-thread-multi-2level /System/Library/Perl/
> 5.8.8 /Library/Perl/5.8.8/darwin-thread-multi-2level /Library/Perl/
> 5.8.8 /Library/Perl /Network/Library/Perl/5.8.8/darwin-thread-
> multi-2level /Network/Library/Perl/5.8.8 /Network/Library/Perl /System/
> Library/Perl/Extras/5.8.8/darwin-thread-multi-2level /System/Library/
> Perl/Extras/5.8.8 /Library/Perl/5.8.6 /Library/Perl/5.8.1 .) at ../
> makeInstallDir.pl line 15.
Congratulations, you found the first bug in Base R3.14.11! We obviously
didn't test the INSTALL_LOCATION configuration option properly before the
release, for which I apologize.
Apply the attached patch to your src/softIoc/Makefile to fix the problem.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Index: Makefile
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/softIoc/Makefile,v
retrieving revision 1.1.2.10
diff -d -u -b -B -p -r1.1.2.10 Makefile
--- Makefile 31 Jul 2009 16:46:12 -0000 1.1.2.10
+++ Makefile 2 Sep 2009 15:27:21 -0000
@@ -11,6 +11,8 @@ include $(TOP)/configure/CONFIG
PROD_IOC = softIoc
+PERL_SCRIPTS += makeInstallDir.pl
INC += epicsInstallDir.h
DBD += softIoc.dbd
@@ -28,5 +30,5 @@ DB += softIocExit.db
include $(TOP)/configure/RULES
-$(COMMON_DIR)/epicsInstallDir.h:
- $(PERL) ../makeInstallDir.pl $(INSTALL_LOCATION) > $@
+$(COMMON_DIR)/epicsInstallDir.h: $(INSTALL_BIN)/makeInstallDir.pl
+ $(PERL) $(INSTALL_BIN)/makeInstallDir.pl $(INSTALL_LOCATION) > $@
- RE: Problem building EPICS base 3.14.11 Adams, Billy R. (LARC-D502)[RAYTHEON TECHNICAL SERVICES COMPANY]
- Problem building EPICS base 3.14.11 Juan Carlos Guzman
Re: aSub vs. genSub - Documentation? Andrew Johnson
<2009>
2025
2026
<2009>
2025
2026
