Andrew,
Probably a dumb question, but why did the unzipped/untarred "baseR3.14.11.tar.gz" change periods in the EPICS top directory name to dashes?
Version R3.14.10 and before used R3.14.10
and
Version R3.14.11 uses R3-14-11
as the top directory name.
Currently modifying facility application compile scripts to replace the periods with dashes in an effort to upgrade to R3.14.11. Was not hard to find, just very confusing.
Billy R. Adams
NASA-Langley Research Center
PH: 757-874-3195
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Wednesday, September 02, 2009 12:00 PM
To: [email protected]
Subject: Re: Problem building EPICS base 3.14.11
Hi Juan Carlos,
On Wednesday 02 September 2009 07:05:27 Juan Carlos Guzman wrote:
> The following message appears when building EPICS base 3.14.11 with
> INSTALL_LOCATION=<some_path_different_to_top> in configure/
> CONFIG_SITE. This problem appears in darwin-x86 (MacBook Pro) and
> linux-x86 (Linux debian etch). In this case, TOP=/opt/epics/3.14.11/
> base and INSTALL_LOCATION=/opt/epics/3.14.11/install
> perl ../makeInstallDir.pl /opt/epics/3.14.11/install > ../O.Common/
> epicsInstallDir.h Can't locate EPICS/Path.pm in @INC (@INC contains:
> /opt/epics/3.14.11/ base/src/softIoc/../../lib/perl
> /Library/Perl/Updates/5.8.8 /System/
> Library/Perl/5.8.8/darwin-thread-multi-2level /System/Library/Perl/
> 5.8.8 /Library/Perl/5.8.8/darwin-thread-multi-2level /Library/Perl/
> 5.8.8 /Library/Perl /Network/Library/Perl/5.8.8/darwin-thread-
> multi-2level /Network/Library/Perl/5.8.8 /Network/Library/Perl
> /System/ Library/Perl/Extras/5.8.8/darwin-thread-multi-2level
> /System/Library/
> Perl/Extras/5.8.8 /Library/Perl/5.8.6 /Library/Perl/5.8.1 .) at ../
> makeInstallDir.pl line 15.
Congratulations, you found the first bug in Base R3.14.11! We obviously didn't test the INSTALL_LOCATION configuration option properly before the release, for which I apologize.
Apply the attached patch to your src/softIoc/Makefile to fix the problem.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
- Re: Problem building EPICS base 3.14.11 Andrew Johnson
<2009>
2025
2026
<2009>
2025
2026
