1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem building EPICS base 3.14.11
To: "Adams, Billy R. (LARC-D502)[RAYTHEON TECHNICAL SERVICES COMPANY]" <[email protected]>
Date: Wed, 2 Sep 2009 12:33:16 -0500
Hi Billy,
On Wednesday 02 September 2009 11:56:05 Adams, Billy R. wrote:
>     Probably a dumb question, but why did the unzipped/untarred
> "baseR3.14.11.tar.gz" change periods in the EPICS top directory name to
> dashes?
There's no fundamental reason, I guess Janet just typed it that way.  To
generate the tar file from the repository we do a cvs export (by hand) with
the appropriate tag to create the directory structure, naming the directory
to export into with the version number, and then tar up that directory.
Because CVS doesn't allow dots in tag names, all our tag names use dashes
instead of dots, and it's easy to get mixed up which to use when typing the
cvs export command:
    cvs export -r R3-14-11 -d base-3.14.11 -kv epics/base
    cvs export -r R3-14-11 -d base-3-14-11 -kv epics/base
>     Currently modifying facility application compile scripts to replace the
> periods with dashes in an effort to upgrade to R3.14.11.  Was not hard to
> find, just very confusing.
Sorry about that, but I would have thought just renaming the directory after
un-tarring it would have been quicker and easier.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
RE: Problem building EPICS base 3.14.11 Adams, Billy R. (LARC-D502)[RAYTHEON TECHNICAL SERVICES COMPANY]
Prev: RE: Problem building EPICS base 3.14.11 Adams, Billy R. (LARC-D502)[RAYTHEON TECHNICAL SERVICES COMPANY]
Next: casr bug Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
