To whomever feels responsible for casr
I found a bug in casr. Empty strings were saved as data{} (in ascii format) but
cannot be restored. The fix below stores empty strings as data{""}.
There are still other issues: It is not possible to restore a string that
contains a quote (") or that ends with a backslash (\). Both result in syntax
errors. Restoring a string that contains special characters like äöü sometimes
hangs up carestore.
Best regards,
Dirk
*** common.c.orig 2009-09-03 11:33:15.000000000 +0200
--- common.c 2009-09-03 11:33:21.000000000 +0200
*** 502,507 ****
--- 502,512 ----
char *p = Value;
+ if (!*p)
+ fputs("\"\"", file);
+ return;
while(*p)
if (!isalnum(*p) && (*p != '.') && (*p != ':') && (*p != '+')
&& (*p != '-') && (*p != '_'))
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- Re: casr bug Andrew Johnson
Re: Problem building EPICS base 3.14.11 Andrew Johnson
<2009>
2025
2026
<2009>
2025
2026
