1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: aSub vs. genSub - Documentation?
To: [email protected]
Cc: "Dr. Peter Zumbruch" <[email protected]>
Date: Wed, 2 Sep 2009 09:48:46 -0500
Hi Peter,
On Wednesday 02 September 2009 06:21:31 Dr. Peter Zumbruch wrote:
> I am looking for documentation of aSub which I cannot find in the
> neither in the WIKI nor elsewhere.
> Are there differences or can one just rely on the genSub documentation
> of Andy Foster?
There are a few differences, but in most cases you should just be able to
replace genSub with aSub in the relevent .db and .c files and the result
usually Just Works{TM}.  The differences as described in the release notes
are:
    * The fields UFA..UFU, UFVA..UFVU, TOVA..TOVU and VERS have been removed.
    * The INPA..INPU and OUTA..OUTU link fields can now be changed at runtime.
    * A new set of fields NEA..NEU and NEVA..NEVU have been added which hold
the current element count for the associated input and ouput fields. These
count fields ensure that putting an array to the A..U or VALA..VALU fields
cannot permanently shorten the number of elements that the array fields can
hold.
    * The default value for the FTA..FTU and FTVA..FTVU fields has been
changed from "STRING" to "DOUBLE", to reduce the memory footprint of unneeded
fields.
    * aSub subroutines can be asynchronous, using the usual method of setting
prec->pact to TRUE before returning and arranging for the record's process()
routine to be called to signal completion. The output links are not written
until the asynchronous completion callback, and input links are not read at
asnychronous completion.
If someone is interested in importing Andy's documentation into the Wiki and
modifying it for the aSub I think quite a few people would be grateful.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
aSub vs. genSub - Documentation? Dr. Peter Zumbruch
Prev: Problem building EPICS base 3.14.11 Juan Carlos Guzman
Next: Re: Problem building EPICS base 3.14.11 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: aSub vs. genSub - Documentation? Dr. Peter Zumbruch
Next: Problem building EPICS base 3.14.11 Juan Carlos Guzman
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
