1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problems with installing EPICS
From: "Rees, Nick (DLSLtd,RAL,DIA)" <[email protected]>
To: "Csaba Gajo" <[email protected]>, <[email protected]>
Date: Fri, 4 Sep 2009 09:27:03 +0100
Hi Csaba,
You said you created your application by:
makeBaseApp.pl -t example myexample3
makeBaseApp.pl -i -t example myexample3
Actually, what I think you did is:
makeBaseApp.pl -t example myexample2
makeBaseApp.pl -i -t example myexample2
... And then didn't take the default when prompted for the application
name, but typed "xxx".
You should have just taken the default, which would have created an
application named myexample2. The prompt text for this response is:
"The following applications are available:
    myexample2
What application should the IOC(s) boot?
The default uses the IOC's name, even if not listed above.
Application name?"
You answered xxx, but this isn't available as an application, so it
couldn't boot. I must admit that this is a bit confusing, but it does
make sense when you know a bit more.
Cheers,
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Csaba Gajo
> Sent: 04 September 2009 09:00
> To: [email protected]
> Subject: Problems with installing EPICS
> Hello,
> I'm having problems with inistalling EPICS on Ubuntu Linux. I've
> downloaded EPICS Base R3.14.10 and the following modules:  Asyn,
> drvIpac and Sequencer compiler 2.0.11. These were all compiled ok.
> I've also installed the GNU readLine library, so I didn't have to
> comment out the line in the config file.
> So it all compiled fine, I've set the environment variables
> in .bashrc:
> export EPICS_CA_ADD_LIST=127.0.0.1
> export EPICS_ROOT=/opt/epics
> export EPICS_HOST_ARCH=linux-x86
> export EPICS_BASE=$EPICS_ROOT/base
> export EPICS_EXTENSIONS=$EPICS_ROOT/extensions
> export PATH=$PATH:$EPICS_BASE/bin/$EPICS_HOST_ARCH
> export
> LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$EPICS_BASE/lib/$EPICS_HOST_A
RCH:$EPICS_EXTENSIONS/lib/$EPICS_HOST_ARCH:$EPICS_APPS/lib/>
$EPICS_HOST_ARCH
> Then I've created an example application in the "work3" directory:
> It all worked fine, I wrote "make" and the application was built.
> However, when I started the application, it didn't work fine. It says
> for example "unknown type ai" and "unknown type calc". I'm guessing it
> cannot find the database. This is the complete output:
> user@ubuntu-vmware:~/work3/iocBoot/iocmyexample2$
> ../../bin/linux-x86/myexample2 st.cmd
> #!../../bin/linux-x86/xxx
> ## You may have to change xxx to something else
> ## everywhere it appears in this file
> < envPaths
> epicsEnvSet("ARCH","linux-x86")
> epicsEnvSet("IOC","iocmyexample2")
> epicsEnvSet("TOP","/home/user/work3")
> epicsEnvSet("EPICS_BASE","/opt/epics/base")
> cd /home/user/work3
> ## Register all support components
> dbLoadDatabase "dbd/xxx.dbd"
> filename="../dbLexRoutines.c" line number=243
> No such file or directory dbRead opening file
> dbd/xxx.dbdxxx_registerRecordDeviceDriver pdbbase
> st.cmd -- Line 12 -- Command xxx_registerRecordDeviceDriver not found.
> ## Load record instances
> dbLoadTemplate "db/userHost.substitutions"
> Record "userHost:aiExample" is of unknown type "ai" - Error at or
> before ")" in file "db/dbExample1.db" line 1
> Record "userHost:calcExample1" is of unknown type "calc" - Error at or
> before ")" in file "db/dbExample2.db" line 1
> Record "userHost:calcExample2" is of unknown type "calc" - Error at or
> Record "userHost:calcExample3" is of unknown type "calc" - Error at or
> dbLoadRecords "db/dbSubExample.db", "user=userHost"
> Record "userHost:subExample" is of unknown type "sub" - Error at or
> before ")" in file "db/dbSubExample.db" line 1
> ## Set this to see messages from mySub
> #var mySubDebug 1
> ## Run this to trace the stages of iocInit
> #traceIocInit
> cd /home/user/work3/iocBoot/iocmyexample2
> iocInit
> Starting iocInit
> ## EPICS R3.14.10 $R3-14-10$ $2008/10/27 19:39:04$
> ## EPICS Base built Sep  3 2009
> initPeriodic: menuScan not present
> iocRun: All initialization complete
> ## Start any sequence programs
> #seq sncExample, "user=userHost"
> epics> exit
> Any idea what could be wrong, and how to fix it?
> Thanks, Csaba
Problems with installing EPICS Csaba Gajo
Prev: Problems with installing EPICS Csaba Gajo
Next: Events Csaba Gajo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Problems with installing EPICS Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
