1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problems with installing EPICS
To: [email protected]
Cc: Csaba Gajo <[email protected]>
Date: Fri, 4 Sep 2009 11:09:30 -0500
Hi Csaba,
Welcome to the EPICS community.
On Friday 04 September 2009 02:59:55 Csaba Gajo wrote:
> So it all compiled fine, I've set the environment variables in .bashrc:
> export EPICS_CA_ADD_LIST=127.0.0.1
The correct name for this variable is EPICS_CA_ADDR_LIST, and you don't
usually need to set it unless you're trying to communicate with IOCs on a
different IP subnet.
> export EPICS_ROOT=/opt/epics
> export EPICS_HOST_ARCH=linux-x86
> export EPICS_BASE=$EPICS_ROOT/base
> export EPICS_EXTENSIONS=$EPICS_ROOT/extensions
> export PATH=$PATH:$EPICS_BASE/bin/$EPICS_HOST_ARCH
> export
> LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$EPICS_BASE/lib/$EPICS_HOST_ARCH:$EPICS_EX
>TENSIONS/lib/$EPICS_HOST_ARCH:$EPICS_APPS/lib/$EPICS_HOST_ARCH
I'm interested why you think you have to set LD_LIBRARY_PATH - did you read
that in our documentation somewhere, and if so where?  Recent versions of the
EPICS Base build rules do not require that you set LD_LIBRARY_PATH, and we
actually recommend *against* doing so unless it's really necessary.  If you
need to build Base so it can be installed in a different location we provide
a better way to do that.  The only time you should really need to set
LD_LIBRARY_PATH is if you don't know where the final install location is
going to be when you compile.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Problems with installing EPICS Csaba Gajo
Prev: Re: Events Ralph Lange
Next: RE: Events Dalesio, Leo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Problems with installing EPICS Rees, Nick (DLSLtd,RAL,DIA)
Next: Events Csaba Gajo
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
