1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Events
To: Csaba Gajo <[email protected]>
Cc: [email protected]
Date: Fri, 04 Sep 2009 11:32:56 -0400
By calling post_event() - or using an eventRecord that will call post_event() if processed.
(See sections 5.5 and 17.3.6 of the AppDevGuide.)
Note, though, that the mechanism is meant for having arbitrary numbers of records react on IOC global events. For your example, the "other" calc record should probably rather CPP link to the VAL field of the first and compare it to 10, or CPP link to the STAT field of the first and compare it to the numerical equivalent of HIHI, depending on what exactly should trigger the "other" record's processing: the value being 10, or the status being HIHI. (Your mail was a bit inconsistent in that detail.)
Hope this helps,
Ralph
Csaba Gajo wrote:
Hello,
I was reading the documentation about events, and was trying to make a
simple program to see how it works. In it I have a calc record, which
increments itself by 1 each second. When the values is 10, it raises a
HIHI signal.
I also have another calc record, whose SCAN field is Event, and it's
supposed to react when the value of the first calc reaches 10.
In the documentation, I was reading that when a user-defined event is
thrown, "all records will be processed whose SCAN field specifies
event and whose event number is the same as the generated event". So,
obviously HIHI is not a user-defined event. How should I throw an
event when the value of calc1 reaches 10?
Regards, Csaba
RE: Events Dalesio, Leo
Events Csaba Gajo
Prev: Re: Events nda
Next: Re: Problems with installing EPICS Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Events Paul Sichta
Next: RE: Events Dalesio, Leo
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
