1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Events
To: [email protected]
Date: Fri, 4 Sep 2009 10:46:54 -0400
Hello,
I was reading the documentation about events, and was trying to make a
simple program to see how it works. In it I have a calc record, which
increments itself by 1 each second. When the values is 10, it raises a
HIHI signal.
I also have another calc record, whose SCAN field is Event, and it's
supposed to react when the value of the first calc reaches 10.
In the documentation, I was reading that when a user-defined event is
thrown, "all records will be processed whose SCAN field specifies
event and whose event number is the same as the generated event". So,
obviously HIHI is not a user-defined event. How should I throw an
event when the value of calc1 reaches 10?
Regards, Csaba
Re: Events Paul Sichta
Re: Events Ralph Lange
Prev: RE: Problems with installing EPICS Rees, Nick (DLSLtd,RAL,DIA)
Next: Re: Events Paul Sichta
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problems with installing EPICS Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
