On Sep 8, 2009, at 8:30 AM, Pierrick Hanlet wrote:
n attempting to build the asyn support package, v4.12, and even
v4.11, I cannot even compile the
package. Initially, I found some spurious characters in the dbd file.
Could your distribution have been corrupted somehow?
What spurious characters did you find? In which dbd file?
I'm now stumped (and have
been since 08:00 today) with the compilation error message.
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -
D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux
-D_REENTRANT -ansi -O3 -Wall -m32 -g -fPIC -I. -I../
O.Common -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -
I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/
miscellaneous -I../../asyn/devEpics -I../../asyn/asynRecord -I../../
asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/
os/Linux -I../../include -I/home/epics/epics/base/include/os/Linux
-I/home/epics/epics/base/include ../../asyn/asynRecord/
asynRecord.c
../../asyn/asynRecord/asynRecord.c: In function ‘init_record’:
../../asyn/asynRecord/asynRecord.c:264: error: ‘asynRecord’ has no
member named ‘dpvt’
../../asyn/asynRecord/asynRecord.c:272: error: ‘asynRecord’ has no
member named ‘dpvt’
../../asyn/asynRecord/asynRecord.c:285: error: ‘asynRecord’ has no
member named ‘udf’
../../asyn/asynRecord/asynRecord.c:296: error: ‘asynRecord’ has no
member named ‘name’
These members are defined in a number of /home/epics/epics/base/
include files of different
record types. Can (will) you kindly assist me?
Is EPICS_BASE set correction in the asyn configure/RELEASE file?
Have you run 'make distclean' from the top of the asyn support module
before trying to run 'make'?
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- asyn compiler problems Pierrick Hanlet
TR: Access security problem GOURNAY Jean-Francois
Re: TR: Access security problem Martin L. Smith
<2009>
2025
2026
Re: asyn compiler problems Emmanuel Mayssat
<2009>
2025
2026
