I think that if you remove the =1 in your CALC expression it will probably work.
So you should have:
CALC("A&1")
CALC("A>>1") .... etc
All CALC expressions must evaluate to TRUE or FALSE so there is no need for
the "=1" in this case.
I usually just use
CALC(A>0&&A<2) rather than "A=1" and
CALC(A>1&&A<3) rather than "A=2"
Just in case the VAL of the PV is not exactly 1 or 2 ...
For the RULE(1 ... and RULE(0 .... this refers to the Access Security Level
(ASL) and has to do with the database record definitions.
The EPICS Application Developers Guide, Chapter 6 states:
"Fields which operators normally change are assigned ASL0. Other
fields are assigned ASL1. For example, the VAL field of an analog output record
is assigned ASL0 and all other
fields ASL1. This is because only the VAL field should be modified during normal
operations."
Allowing write access to Access Security Level 1 implies write access to Access
Security Level 0 but not visa versa.
Hope this helps,
Marty
GOURNAY Jean-Francois wrote:
/This message sent yesterday didn’t show up. ///
Hello
I try the following ASG configuration file:
UAG(tous) {spiral2, spiral2mgr, gournay}
UAG(physique) {spiral2}
UAG(develop) {spiral2mgr}
UAG(gournay) {gournay}
HAG(hag) {dappck110}
ASG(DEFAULT) {
INPA(ASGVAL)
RULE(1,READ)
RULE(1,WRITE) {
UAG(tous)
HAG(hag)
CALC("A&1=1")
RULE(1,WRITE) {
UAG(develop)
HAG(hag)
CALC("A>>1=1")
RULE(1,WRITE) {
UAG(physique)
HAG(hag)
CALC("A>>2=1")
RULE(1,WRITE) {
UAG(gournay)
HAG(hag)
CALC("A>>3=1")
The idea is to change WRITE permission depending on the value of a
longout record ASGVAL (ASGVAL.VAL = 1,2,4,8)
It doesn’t work: for A=1 the 3 users defined in “tous” have WRITE
access whatever UAG. For A != 1 no WRITE access at all. As I am in ASG
DEFAULT, I did’nt specify anything for the ASG Fields in the database.
What is wrong in this scheme?
Another point: I did’nt really understand the meaning of RULE(1 … vs
RULE(0 …
Thanks!
J.F. Gournay
CEA Saclay
IRFU/SIS
- TR: Access security problem GOURNAY Jean-Francois
Re: asyn compiler problems Eric Norum
Re: asyn compiler problems Emmanuel Mayssat
<2009>
2025
2026
RE: Access security problem GOURNAY Jean-Francois
<2009>
2025
2026
