Pierrick Hanlet wrote:
n attempting to build the asyn support package, v4.12, and even v4.11, I cannot even compile the
package. Initially, I found some spurious characters in the dbd file. I'm now stumped (and have
been since 08:00 today) with the compilation error message.
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -m32 -g -fPIC -I. -I../O.Common -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/os/Linux -I../../include -I/home/epics/epics/base/include/os/Linux -I/home/epics/epics/base/include ../../asyn/asynRecord/asynRecord.c
../../asyn/asynRecord/asynRecord.c: In function ‘init_record’:
../../asyn/asynRecord/asynRecord.c:264: error: ‘asynRecord’ has no member named ‘dpvt’
../../asyn/asynRecord/asynRecord.c:272: error: ‘asynRecord’ has no member named ‘dpvt’
../../asyn/asynRecord/asynRecord.c:285: error: ‘asynRecord’ has no member named ‘udf’
../../asyn/asynRecord/asynRecord.c:296: error: ‘asynRecord’ has no member named ‘name’
It seems asyn cannot find dbCommon.dbd where all those fields are declared.
dbCommon is located in the epics base. So check where your
config/configure files are pointing to. (did you 'make' the base?)
These members are defined in a number of /home/epics/epics/base/include files of different
record types. Can (will) you kindly assist me?
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039 office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
- RE: asyn compiler problems Mark Rivers
- asyn compiler problems Pierrick Hanlet
Re: TR: Access security problem Martin L. Smith
<2009>
2025
2026
Re: asyn compiler problems Eric Norum
<2009>
2025
2026
