I don't think the problem is that it cannot find base, at least not at compile time. If that were the case I would expect to see many error messages about not being able to find epicsMutex.h, etc.
I concur with Eric, I think something was corrupted with your download or tar file extraction.
I normally build asyn from a CVS checkout, but just to be sure that there was nothing wrong with the tar.gz file on the asyn Web site, I just downloaded and built asyn from that file on Linux and vxWorks. It built fine, there is nothing wrong with the asynRecord.dbd file.
From: [email protected] on behalf of Emmanuel Mayssat
Sent: Tue 9/8/2009 2:54 PM
To: Pierrick Hanlet
Cc: [email protected]
Subject: Re: asyn compiler problems
Pierrick Hanlet wrote:
> Hi,
> n attempting to build the asyn support package, v4.12, and even v4.11, I cannot even compile the
> package. Initially, I found some spurious characters in the dbd file. I'm now stumped (and have
> been since 08:00 today) with the compilation error message.
> /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -m32 -g -fPIC -I. -I../O.Common -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/os/Linux -I../../include -I/home/epics/epics/base/include/os/Linux -I/home/epics/epics/base/include ../../asyn/asynRecord/asynRecord.c
> ../../asyn/asynRecord/asynRecord.c: In function 'init_record':
> ../../asyn/asynRecord/asynRecord.c:264: error: 'asynRecord' has no member named 'dpvt'
> ../../asyn/asynRecord/asynRecord.c:272: error: 'asynRecord' has no member named 'dpvt'
> ../../asyn/asynRecord/asynRecord.c:285: error: 'asynRecord' has no member named 'udf'
> ../../asyn/asynRecord/asynRecord.c:296: error: 'asynRecord' has no member named 'name'
It seems asyn cannot find dbCommon.dbd where all those fields are declared.
dbCommon is located in the epics base. So check where your
config/configure files are pointing to. (did you 'make' the base?)
> These members are defined in a number of /home/epics/epics/base/include files of different
> record types. Can (will) you kindly assist me?
> Thanks,
> Pierrick
> Pierrick Hanlet
> Fermilab, P.O. Box 500, M.S. 122
> Batavia, IL 60510
> [email protected]
> (630)840-5555/8871/6039 office/lab/fax
> http://www-d0.fnal.gov/~hanlet
> "Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
- Re: RE: asyn compiler problems Pierrick Hanlet
- asyn compiler problems Pierrick Hanlet
- Re: asyn compiler problems Emmanuel Mayssat
<2009>
2025
2026
<2009>
2025
2026
