Thanks for the help; there was a problem with file corruption. I deleted the tarball, reloaded,
reextracted, and rebuilt. All is well.
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039 office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
----- Original Message -----
Date: Tuesday, September 8, 2009 3:35 pm
Subject: RE: asyn compiler problems
To: Emmanuel Mayssat <[email protected]>, Pierrick Hanlet <[email protected]>
Cc: [email protected]
> I don't think the problem is that it cannot find base, at least not at
> compile time. If that were the case I would expect to see many error
> messages about not being able to find epicsMutex.h, etc.
> I concur with Eric, I think something was corrupted with your download
> or tar file extraction.
> I normally build asyn from a CVS checkout, but just to be sure that
> there was nothing wrong with the tar.gz file on the asyn Web site, I
> just downloaded and built asyn from that file on Linux and vxWorks.
> It built fine, there is nothing wrong with the asynRecord.dbd file.
> Mark
> ________________________________
> From: [email protected] on behalf of Emmanuel Mayssat
> Sent: Tue 9/8/2009 2:54 PM
> To: Pierrick Hanlet
> Subject: Re: asyn compiler problems
> Pierrick Hanlet wrote:
> > Hi,
> > n attempting to build the asyn support package, v4.12, and even
> v4.11, I cannot even compile the
> > package. Initially, I found some spurious characters in the dbd
> file. I'm now stumped (and have
> > been since 08:00 today) with the compilation error message.
> > /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux
> -D_REENTRANT -ansi -O3 -Wall -m32 -g -fPIC -I.
> -I../O.Common -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib
> -I../../asyn/drvAsynSerial -I../../asyn/interfaces
> -I../../asyn/miscellaneous -I../../asyn/devEpics
> -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014
> -I../../asyn/devGpib -I../../include/os/Linux -I../../include
> -I/home/epics/epics/base/include/os/Linux
> -I/home/epics/epics/base/include ../../asyn/asynRecord/asynRecord.c
> > ../../asyn/asynRecord/asynRecord.c: In function 'init_record':
> > ../../asyn/asynRecord/asynRecord.c:264: error: 'asynRecord' has no
> member named 'dpvt'
> > ../../asyn/asynRecord/asynRecord.c:272: error: 'asynRecord' has no
> member named 'dpvt'
> > ../../asyn/asynRecord/asynRecord.c:285: error: 'asynRecord' has no
> member named 'udf'
> > ../../asyn/asynRecord/asynRecord.c:296: error: 'asynRecord' has no
> member named 'name'
> It seems asyn cannot find dbCommon.dbd where all those fields are declared.
> dbCommon is located in the epics base. So check where your
> config/configure files are pointing to. (did you 'make' the base?)
> > These members are defined in a number of
> /home/epics/epics/base/include files of different
> > record types. Can (will) you kindly assist me?
> > Thanks,
> > Pierrick
> > Pierrick Hanlet
> > Batavia, IL 60510
> > [email protected]
- asyn compiler problems Pierrick Hanlet
- Re: asyn compiler problems Emmanuel Mayssat
- RE: asyn compiler problems Mark Rivers
RE: sequencer feature request Mark Rivers
<2009>
2025
2026
TR: Access security problem GOURNAY Jean-Francois
<2009>
2025
2026
