1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Python client application survey
To: [email protected], [email protected], [email protected], John Hammonds <[email protected]>, [email protected]
Date: Wed, 30 Sep 2009 09:58:56 -0500
Hi Noboru, Wang, John, Michael, all,
As I've said before, I would be happy to collaborate to come up with a
more uniform approach to using CA with Python.
I agree with Noboru that a two-tier approach is needed.  I'm not so
sure that a 'thin wrapper to all of ca' is crucial.
For example, I don't see significant advantages to having all the C CA
types (DBR_SHORT, DBR_INT, DBR_LONG, etc) exposed to Python at all, as
Python does not distinguish these types, and the difference never
needs to be exposed to the Python programmer.  The DBR_ type for a
channel is an implementation detail that is important in C, but not in
Python.  One should be able to create a channel/PV in Python without
knowing its underlying type.  One should be able to ask for the "extra
information" in a DBR_***_CTRL type (and possibly _STS, _GR types),
but I see no advantage to having 'ca.DBR_LONG' existing in Python.  I
also think there is no point in ever seeing the Channel ID in Python,
as this should always be inside a Channel or PV object.
In addition, exposing CA threads to Python is complicated, and simply
wrapping the C code and telling the Python programmer to deal with the
problem "just like C" seems like a poor choice to me.  The Python
Global Interpreter Lock makes using CA with Python threads perilous:
can a channel/PV in one thread call code in another thread?  Can CA
threads be used with other threading code (GUIs, for example).
Perhaps the Cothreads approach or using subprocess is a better
solution.  I am not sure sure that using preemptive callbacks can
really work in Python, as it would allow a CA C thread to call a
Python function when non-CA Python code is running.....  What happens
if that C thread does not hold the Python GIL?
I also think there are things which are done well at the C level to
help a Python wrapper that would not be part of a 'thin wrapper':
automatically fetching enum string names, a simple "put and wait until
done" method, managing a set of PV connections, and so forth.  These
may seem like "extras" to a C programmer, but they are not to a Python
interface.
Finally, I think documentation is crucial, and find it somewhat
lacking in several of the existing interfaces.
Again, I'd be happy to collaborate on these to make a better and more
uniform python interface.  But I do think there are important details
to be worked out beyond exposing a low-level interface to the C
library.
Cheers,
--Matt Newville <newville at cars.uchicago.edu>
RE: EPICS Python client application survey michael.abbott
Re: EPICS Python client application survey Benjamin Franksen
Re: EPICS Python client application survey Tim Mooney
Prev: RE: Problem with cothread-1-14 in linux-x86_64 michael.abbott
Next: RE: EPICS Python client application survey michael.abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS Python client application survey michael.abbott
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
