1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: error building mca6-11
To: "Mark Rivers" <[email protected]>, <[email protected]>, "tech-talk" <[email protected]>
Date: Fri, 20 Nov 2009 08:18:46 -0600
Hi Geyang,
I've looked more closely.  First, this definition:
typedef uint32_t u_int32_t;
is in libnet-types.h, not libnet-headers.h.  But it only applies for __sun__ && __svr4__, so it is not used in your case.
That means it is relying on a system definition for u_int32_t.
u_int32_t is defined in sys/types.h, but there is some GNUC_PREREQ #ifdef around it, and it seems to not be defined for GCC 2.7 and later, i.e. only for very early code?
So I am confused, I don't know where u_int32_t is being defined on my system, but it must be, because I don't get the error you are getting.
Sent: Fri 11/20/2009 7:41 AM
To: [email protected]; tech-talk
Hi Geyang,
I have not seen that problem.
But I can see that the problem is that the type u_int32_t is not defined.  This probably has to do with the version of Linux or the gnu compiler you are using.
The file libnet-headers.h, which is included before libnet-functions.h in libnet.h, contains the following line:
So the problem must be that the type uint32_t is not defined.
In a search of typedefs for uint32_t on my system I see that it is defined in several files, including /usr/include/stdint.h.
For some reason it is not being defined when you build libnet.  You could try adding:
#include <stdint.h>
before the line
#include <libnet.h>
in nmc_sys_defs.h
and see if that fixes the problem.
Sent: Thu 11/19/2009 11:28 PM
To: tech-talk
Cc: Mark Rivers
Subject: error building mca6-11
hi,
when I tried to compile the mcaR6-11/10, I met following errors:
/usr/bin/gcc-4.2 -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi   -O3   -Wall     -g `libnet-config --defines`   -m32     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include  -I/usr/local/epics/r3.14.10/modules/soft/seq/2-0-12/include  -I/usr/local/epics/r3.14.10/modules/soft/calc/2-6-7/include  -I/usr/local/epics/r3.14.10/modules/soft/sscan/2-6-5/include  -I/usr/local/epics/r3.14.10/modules/soft/busy/1-1/include  -I/usr/local/epics/r3.14.10/modules/soft/std/2-6/include    -I/usr/local/epics/r3.14.10/modules/soft/asyn/4-12/include -I/usr/local/epics/r3.14.10/modules/soft/mca/6-11/include/os/Linux -I/usr/local/epics/r3.14.10/modules/soft/mca/6-11/include -I/usr/local/epics/r3.14.10/base/include/os/Linux -I/usr/local/epics/r3.14.10/base/include        ../nmc_comm_subs_1.c
In file included from /usr/include/libnet.h:124,
                 from ../nmc_sys_defs.h:56,
                 from ../nmc_comm_subs_1.c:69:
/usr/include/./libnet/libnet-functions.h:1432: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'u_int32_t'
make[3]: *** [nmc_comm_subs_1.o] Error 1
make[3]: Leaving directory `/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp/CanberraSrc/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp/CanberraSrc'
make[1]: *** [CanberraSrc.install] Error 2
make[1]: Leaving directory `/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp'
make: *** [mcaApp.install] Error 2
root@cow1:/usr/local/epics/r3.14.10/modules/soft/mca/6-11#
Any suggestion?  thanks a lot.
ps, I use ubuntu, libnet1 with apt-get install ,not from source compilation.
Best regards
Geyang  2009-11-20
error building mca6-11 Silver
RE: error building mca6-11 Mark Rivers
Prev: RE: error building mca6-11 Mark Rivers
Next: RE: error building mca6-11 Davidsaver, Michael
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: RE: RE: error building mca6-11 Silver
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
