1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RE: RE: error building mca6-11
To: "Mark Rivers" <[email protected]>, "tech-talk" <[email protected]>
Date: Sat, 21 Nov 2009 10:53:37 +0800
hi, Mark:
  thanks for informing Tim to correct the URL. Now I try to run areaDetector1.4 under fedora10,  while ioc crashes, erros is shown as following. I want to know if the camera can't be connected, the ioc will crash by an Segmentation fault error?  To clarify it, do you need a core dump file to debug it?
  thanks a lot for your help.
[root@cow2]:/usr/local/epics/r3.14.10/support/areaDetector/1-4/iocBoot/iocProsilica>../../bin/linux-x86/prosilicaApp st.cmd.linux
< envPaths.linux
epicsEnvSet("ARCH","linux-x86")
epicsEnvSet("IOC","iocaaa")
epicsEnvSet("TOP","/usr/local/epics/r3.14.10/support/areaDetector/1-4")
epicsEnvSet("EPICS_BASE","/usr/local/epics/r3.14.10/base")
epicsEnvSet("AREA_DETECTOR","/usr/local/epics/r3.14.10/support/areaDetector/1-4")
epicsEnvSet("AUTOSAVE","/usr/local/epics/r3.14.10/support/autosave/4-5")
< st.cmd
errlogInit(20000)
dbLoadDatabase("/usr/local/epics/r3.14.10/support/areaDetector/1-4/dbd/prosilicaApp.dbd")
prosilicaApp_registerRecordDeviceDriver(pdbbase)
prosilicaConfig("PS1", 51039, 50, 200000000)
2009/11/22 10:57:30.894 prosilica:connectCamera: Cannot find camera 51039
prosilica:prosilica: cannot connect to camera 51039, manually connect when available.
asynSetTraceIOMask("PS1",0,2)
#asynSetTraceMask("PS1",0,255)
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/ADBase.template",   "P=13PS1:,R=cam1:,PORT=PS1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDFile.template",   "P=13PS1:,R=cam1:,PORT=PS1,ADDR=0,TIMEOUT=1")
# Note that prosilica.template must be loaded after NDFile.template to replace the file format correctly
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/prosilica.template","P=13PS1:,R=cam1:,PORT=PS1,ADDR=0,TIMEOUT=1")
#prosilicaConfig("PS2", 50022, 10, 50000000)
#dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/ADBase.template",   "P=13PS1:,R=cam2:,PORT=PS2,ADDR=0,TIMEOUT=1")
#dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/prosilica.template","P=13PS1:,R=cam2:,PORT=PS2,ADDR=0,TIMEOUT=1")
# Create a standard arrays plugin, set it to get data from first Prosilica driver.
drvNDStdArraysConfigure("PS1Image", 5, 0, "PS1", 0, -1)
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDPluginBase.template","P=13PS1:,R=image1:,PORT=PS1Image,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PS1,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDStdArrays.template", "P=13PS1:,R=image1:,PORT=PS1Image,ADDR=0,TIMEOUT=1,SIZE=8,FTVL=UCHAR,NELEMENTS=4177920")
# Load the database to use with Stephen Mudie's IDL code
#dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/EPICS_AD_Viewer.template", "P=13PS1:, R=image1:")
# Create a file saving plugin
drvNDFileConfigure("PS1File", 5, 0, "PS1", 0)
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDPluginBase.template","P=13PS1:,R=file1:,PORT=PS1File,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PS1,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDFile.template",      "P=13PS1:,R=file1:,PORT=PS1File,ADDR=0,TIMEOUT=1")
# Create an ROI plugin
drvNDROIConfigure("PS1ROI", 5, 0, "PS1", 0, 10, 20, -1)
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDPluginBase.template","P=13PS1:,R=ROI1:,  PORT=PS1ROI,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PS1,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDROI.template",       "P=13PS1:,R=ROI1:,  PORT=PS1ROI,ADDR=0,TIMEOUT=1")
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDROIN.template",      "P=13PS1:,R=ROI1:0:,PORT=PS1ROI,ADDR=0,TIMEOUT=1,HIST_SIZE=256")
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDROIN.template",      "P=13PS1:,R=ROI1:1:,PORT=PS1ROI,ADDR=1,TIMEOUT=1,HIST_SIZE=256")
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDROIN.template",      "P=13PS1:,R=ROI1:2:,PORT=PS1ROI,ADDR=2,TIMEOUT=1,HIST_SIZE=256")
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDROIN.template",      "P=13PS1:,R=ROI1:3:,PORT=PS1ROI,ADDR=3,TIMEOUT=1,HIST_SIZE=256")
# Create 2 color conversion plugins
drvNDColorConvertConfigure("PS1CC1", 5, 0, "PS1", 0, 20, -1)
NDPluginColorConvert:NDPluginColorConvert: failed to set integer param for color mode
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDPluginBase.template","   P=13PS1:,R=CC1:,  PORT=PS1CC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PS1,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDColorConvert.template", "P=13PS1:,R=CC1:,  PORT=PS1CC1,ADDR=0,TIMEOUT=1")
drvNDColorConvertConfigure("PS1CC2", 5, 0, "PS1", 0, 20, -1)
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDPluginBase.template","   P=13PS1:,R=CC2:,  PORT=PS1CC2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PS1CC1,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-4/ADApp/Db/NDColorConvert.template", "P=13PS1:,R=CC2:,  PORT=PS1CC2,ADDR=0,TIMEOUT=1")
#set_requestfile_path("./")
#set_savefile_path("./autosave")
#set_requestfile_path("$(AREA_DETECTOR)/ADApp/Db")
#set_pass0_restoreFile("auto_settings.sav")
#set_pass1_restoreFile("auto_settings.sav")
#save_restoreSet_status_prefix("13PS1:")
#dbLoadRecords("$(AUTOSAVE)/asApp/Db/save_restoreStatus.db", "P=13PS1:")
iocInit()
Starting iocInit
## EPICS R3.14.10 $R3-14-10$ $2008/10/27 19:39:04$
## EPICS Base built Nov 12 2009
2009/11/22 10:57:31.418 13PS1:cam1:AcquirePeriod_RBV devAsynFloat64::process read error asynPortDriver:readFloat64: status=3, function=26, value=0.000000
2009/11/22 10:57:31.418 13PS1:cam1:AcquireTime_RBV devAsynFloat64::process read error asynPortDriver:readFloat64: status=3, function=25, value=0.000000
2009/11/22 10:57:31.418 13PS1:cam1:PSFrameRate_RBV devAsynFloat64::process read error asynPortDriver:readFloat64: status=3, function=63, value=0.000000
2009/11/22 10:57:31.418 13PS1:cam1:Manufacturer_RBV devAsynOctet: readIt failed asynPortDriver:readOctet: status=3, function=1, value=
The CA server's beacon address list was empty after initialization?
2009/11/22 10:57:31.419 13PS1:cam1:Model_RBV devAsynOctet: readIt failed asynPortDriver:readOctet: status=3, function=2, value=
#asynSetTraceMask("PS1",0,1)
2009/11/22 10:57:31.419 13PS1:cam1:PSDriverType_RBV devAsynOctet: readIt failed asynPortDriver:readOctet: status=3, function=61, value=
# save things every thirty seconds
2009/11/22 10:57:31.419 13PS1:cam1:PSFilterVersion_RBV devAsynOctet: readIt failed asynPortDriver:readOctet: status=3, function=62, value=
create_monitor_set("auto_settings.req", 30,"P=13PS1:,D=cam1:")
2009/11/22 10:57:31.420 13PS1:cam1:Strobe1Delay_RBV devAsynFloat64::process read error asynPortDriver:readFloat64: status=3, function=84, value=0.000000
2009/11/22 10:57:31.420 13PS1:cam1:Strobe1Duration_RBV devAsynFloat64::process read error asynPortDriver:readFloat64: status=3, function=86, value=0.000000
2009/11/22 10:57:31.420 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.420 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.420 prosilica:writeFloat64: error, status=3 function=26, value=0.010000
2009/11/22 10:57:31.420 13PS1:cam1:AcquirePeriod devAsynFloat64 process error
2009/11/22 10:57:31.420 prosilica:writeFloat64: error, status=3 function=25, value=0.000000
2009/11/22 10:57:31.420 13PS1:cam1:AcquireTime devAsynFloat64 process error
2009/11/22 10:57:31.420 prosilica:writeFloat64: error, status=3 function=3, value=1.000000
2009/11/22 10:57:31.420 13PS1:cam1:Gain devAsynFloat64 process error
save_restore:readReqFile: unable to open file ADBase_settings.req. Exiting.
2009/11/22 10:57:31.421 prosilica:writeFloat64: error, status=3 function=34, value=0.000000
2009/11/22 10:57:31.421 13PS1:cam1:ShutterCloseDelay devAsynFloat64 process error
2009/11/22 10:57:31.421 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.421 prosilica:setGeometry: error, status=3
save_restore:readReqFile: unable to open file NDFile_settings.req. Exiting.
2009/11/22 10:57:31.421 prosilica:writeFloat64: error, status=3 function=33, value=0.000000
2009/11/22 10:57:31.421 13PS1:cam1:ShutterOpenDelay devAsynFloat64 process error
save_restore:readReqFile: unable to open file NDPluginBase_settings.req. Exiting.
save_restore:readReqFile: unable to open file NDStdArrays_settings.req. Exiting.
2009/11/22 10:57:31.421 prosilica:writeFloat64: error, status=3 function=84, value=0.000000
2009/11/22 10:57:31.421 13PS1:cam1:Strobe1Delay devAsynFloat64 process error
2009/11/22 10:57:31.421 prosilica:writeFloat64: error, status=3 function=86, value=0.000000
2009/11/22 10:57:31.421 13PS1:cam1:Strobe1Duration devAsynFloat64 process error
2009/11/22 10:57:31.421 prosilica:writeFloat64: error, status=3 function=35, value=0.000000
2009/11/22 10:57:31.421 13PS1:cam1:Temperature devAsynFloat64 process error
save_restore:readReqFile: unable to open file NDROI_settings.req. Exiting.
save_restore:readReqFile: unable to open file NDROIN_settings.req. Exiting.
2009/11/22 10:57:31.422 13PS1:cam1:Strobe1CtlDuration_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=85, value=0
2009/11/22 10:57:31.422 13PS1:cam1:SyncIn1Level_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=72, value=0
2009/11/22 10:57:31.422 13PS1:cam1:SyncIn2Level_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=73, value=0
2009/11/22 10:57:31.422 13PS1:cam1:SyncOut1Invert_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=76, value=0
2009/11/22 10:57:31.422 13PS1:cam1:SyncOut1Level_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=75, value=0
2009/11/22 10:57:31.422 13PS1:cam1:SyncOut2Invert_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=79, value=0
2009/11/22 10:57:31.422 13PS1:cam1:SyncOut2Level_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=78, value=0
2009/11/22 10:57:31.422 13PS1:cam1:SyncOut3Invert_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=82, value=0
2009/11/22 10:57:31.422 13PS1:cam1:SyncOut3Level_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=81, value=0
2009/11/22 10:57:31.422 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.422 prosilica:setGeometry: error, status=3
save_restore:readReqFile: unable to open file NDColorConvert_settings.req. Exiting.
2009/11/22 10:57:31.422 prosilica:writeInt32: error, status=3 function=59, value=1
2009/11/22 10:57:31.422 13PS1:cam1:ArrayCallbacks devAsynInt32 process error
2009/11/22 10:57:31.422 prosilica:writeInt32: error, status=3 function=44, value=0
2009/11/22 10:57:31.423 13PS1:cam1:AutoIncrement devAsynInt32 process error
2009/11/22 10:57:31.423 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.423 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.423 prosilica:writeInt32: error, status=3 function=47, value=0
2009/11/22 10:57:31.423 13PS1:cam1:AutoSave devAsynInt32 process error
2009/11/22 10:57:31.423 prosilica:writeInt32: error, status=3 function=12, value=0
2009/11/22 10:57:31.423 13PS1:cam1:ReverseX devAsynInt32 process error
2009/11/22 10:57:31.424 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.424 prosilica:writeInt32: error, status=3 function=13, value=0
2009/11/22 10:57:31.424 13PS1:cam1:ReverseY devAsynInt32 process error
2009/11/22 10:57:31.424 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.424 prosilica:writeInt32: error, status=3 function=29, value=0
2009/11/22 10:57:31.424 13PS1:cam1:ShutterControl devAsynInt32 process error
2009/11/22 10:57:31.425 prosilica:writeInt32: error, status=3 function=85, value=0
2009/11/22 10:57:31.425 13PS1:cam1:Strobe1CtlDuration devAsynInt32 process error
2009/11/22 10:57:31.425 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.425 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.425 prosilica:writeInt32: error, status=3 function=76, value=0
2009/11/22 10:57:31.425 13PS1:cam1:SyncOut1Invert devAsynInt32 process error
2009/11/22 10:57:31.425 prosilica:writeInt32: error, status=3 function=75, value=0
2009/11/22 10:57:31.425 13PS1:cam1:SyncOut1Level devAsynInt32 process error
2009/11/22 10:57:31.426 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.426 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.426 prosilica:writeInt32: error, status=3 function=79, value=0
2009/11/22 10:57:31.426 13PS1:cam1:SyncOut2Invert devAsynInt32 process error
2009/11/22 10:57:31.426 prosilica:writeInt32: error, status=3 function=78, value=0
2009/11/22 10:57:31.426 13PS1:cam1:SyncOut2Level devAsynInt32 process error
2009/11/22 10:57:31.427 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.427 prosilica:writeInt32: error, status=3 function=82, value=0
2009/11/22 10:57:31.427 13PS1:cam1:SyncOut3Invert devAsynInt32 process error
2009/11/22 10:57:31.427 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.427 prosilica:writeInt32: error, status=3 function=81, value=0
2009/11/22 10:57:31.427 13PS1:cam1:SyncOut3Level devAsynInt32 process error
2009/11/22 10:57:31.427 13PS1:cam1:MaxSizeX_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=10, value=0
2009/11/22 10:57:31.427 13PS1:cam1:MaxSizeY_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=11, value=0
2009/11/22 10:57:31.428 13PS1:cam1:PSBadFrameCounter_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=71, value=0
2009/11/22 10:57:31.428 13PS1:cam1:PSFramesCompleted_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=64, value=0
2009/11/22 10:57:31.428 13PS1:cam1:PSFramesDropped_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=65, value=0
2009/11/22 10:57:31.428 13PS1:cam1:PSPacketsErroneous_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=66, value=0
2009/11/22 10:57:31.428 13PS1:cam1:PSPacketsMissed_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=67, value=0
2009/11/22 10:57:31.428 13PS1:cam1:PSPacketsReceived_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=68, value=0
2009/11/22 10:57:31.428 13PS1:cam1:PSPacketsRequested_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=69, value=0
2009/11/22 10:57:31.428 13PS1:cam1:PSPacketsResent_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=70, value=0
2009/11/22 10:57:31.428 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.429 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.429 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.429 prosilica:writeInt32: error, status=3 function=4, value=1
2009/11/22 10:57:31.429 13PS1:cam1:BinX devAsynInt32 process error
2009/11/22 10:57:31.429 prosilica:writeInt32: error, status=3 function=5, value=1
2009/11/22 10:57:31.429 13PS1:cam1:BinY devAsynInt32 process error
2009/11/22 10:57:31.429 prosilica:writeInt32: error, status=3 function=42, value=0
2009/11/22 10:57:31.429 13PS1:cam1:FileNumber devAsynInt32 process error
2009/11/22 10:57:31.429 prosilica:writeInt32: error, status=3 function=6, value=0
2009/11/22 10:57:31.429 13PS1:cam1:MinX devAsynInt32 process error
2009/11/22 10:57:31.429 prosilica:writeInt32: error, status=3 function=7, value=0
2009/11/22 10:57:31.429 13PS1:cam1:MinY devAsynInt32 process error
2009/11/22 10:57:31.429 prosilica:writeInt32: error, status=3 function=51, value=0
2009/11/22 10:57:31.429 13PS1:cam1:NumCapture devAsynInt32 process error
2009/11/22 10:57:31.430 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.430 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.430 prosilica:writeInt32: error, status=3 function=23, value=1
2009/11/22 10:57:31.430 13PS1:cam1:NumExposures devAsynInt32 process error
2009/11/22 10:57:31.430 prosilica:writeInt32: error, status=3 function=24, value=0
2009/11/22 10:57:31.430 13PS1:cam1:NumImages devAsynInt32 process error
2009/11/22 10:57:31.430 prosilica:writeInt32: error, status=3 function=8, value=1
2009/11/22 10:57:31.430 13PS1:cam1:SizeX devAsynInt32 process error
2009/11/22 10:57:31.430 prosilica:writeInt32: error, status=3 function=9, value=1
2009/11/22 10:57:31.430 13PS1:cam1:SizeY devAsynInt32 process error
2009/11/22 10:57:31.430 13PS1:cam1:Strobe1Mode_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=83, value=0
2009/11/22 10:57:31.430 13PS1:cam1:SyncOut1Mode_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=74, value=0
2009/11/22 10:57:31.433 13PS1:cam1:SyncOut2Mode_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=77, value=0
2009/11/22 10:57:31.434 13PS1:cam1:SyncOut3Mode_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=80, value=0
2009/11/22 10:57:31.434 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.434 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.434 prosilica:writeInt32: error, status=3 function=19, value=0
2009/11/22 10:57:31.434 13PS1:cam1:ColorMode devAsynInt32 process error
2009/11/22 10:57:31.434 prosilica:writeInt32: error, status=3 function=18, value=1
2009/11/22 10:57:31.434 13PS1:cam1:DataType devAsynInt32 process error
2009/11/22 10:57:31.435 prosilica:writeInt32: error, status=3 function=46, value=0
2009/11/22 10:57:31.435 13PS1:cam1:FileFormat devAsynInt32 process error
2009/11/22 10:57:31.435 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.435 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.435 prosilica:writeInt32: error, status=3 function=50, value=0
2009/11/22 10:57:31.435 13PS1:cam1:FileWriteMode devAsynInt32 process error
2009/11/22 10:57:31.435 prosilica:writeInt32: error, status=3 function=20, value=0
2009/11/22 10:57:31.435 13PS1:cam1:FrameType devAsynInt32 process error
2009/11/22 10:57:31.436 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.436 prosilica:writeInt32: error, status=3 function=21, value=0
2009/11/22 10:57:31.436 13PS1:cam1:ImageMode devAsynInt32 process error
2009/11/22 10:57:31.436 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.436 prosilica:writeInt32: error, status=3 function=32, value=0
2009/11/22 10:57:31.436 13PS1:cam1:ShutterMode devAsynInt32 process error
2009/11/22 10:57:31.437 prosilica:writeInt32: error, status=3 function=83, value=0
2009/11/22 10:57:31.437 13PS1:cam1:Strobe1Mode devAsynInt32 process error
2009/11/22 10:57:31.437 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.437 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.437 prosilica:writeInt32: error, status=3 function=74, value=0
2009/11/22 10:57:31.437 13PS1:cam1:SyncOut1Mode devAsynInt32 process error
2009/11/22 10:57:31.437 prosilica:writeInt32: error, status=3 function=77, value=0
2009/11/22 10:57:31.437 13PS1:cam1:SyncOut2Mode devAsynInt32 process error
2009/11/22 10:57:31.438 prosilica:setGeometry: error unsupported data type 1 and/or color mode 0
2009/11/22 10:57:31.438 prosilica:setGeometry: error, status=3
2009/11/22 10:57:31.438 prosilica:writeInt32: error, status=3 function=80, value=0
2009/11/22 10:57:31.438 13PS1:cam1:SyncOut3Mode devAsynInt32 process error
2009/11/22 10:57:31.438 prosilica:writeInt32: error, status=3 function=22, value=0
2009/11/22 10:57:31.438 13PS1:cam1:TriggerMode devAsynInt32 process error
fc10 epics> Segmentation fault
======= At 2009-11-21, 01:44:18 you wrote: =======
>Hi Geyang,
>I am running areaDetector on several different versions of Linux.  These
>include:
>Fedora Core 9 (2.6.27)
>Fedora Core 10 (2.6.27)
>SUSE 2.6.22
>Redhat (2.6.18)
>Mark
>-----Original Message-----
>From: Silver [mailto:[email protected]]
>Sent: Friday, November 20, 2009 8:22 AM
>To: Mark Rivers
>Subject: Re: RE: error building mca6-11
>hi, Mark:
>  Thanks for you replay. I will check it later. anyway, it can be
>compiled on fedora system. so as you said, it must be with the version
>of linux or gnu.
>  while I want to ask more questions about the module of
>areadetector(http://cars9.uchicago.edu/software/epics/areaDetector.html)
>. on it, you list the software version and its required modules version.
>for example, version 1.5 should need busy record 1.2, I can only find
>version 1.1 version busy record (http://www.aps.anl.gov/bcda/synApps/).
>Is it possible for you to give a url for those required modules?
>  ps, could you tell me your linux version running areadector?
>======= At 2009-11-20, 21:41:39 you wrote: =======
>>Hi Geyang,
>>I have not seen that problem.
>>But I can see that the problem is that the type u_int32_t is not
>defined.  This probably has to do with the version of Linux or the gnu
>compiler you are using.
>>The file libnet-headers.h, which is included before libnet-functions.h
>in libnet.h, contains the following line:
>>typedef uint32_t u_int32_t;
>>So the problem must be that the type uint32_t is not defined.
>>In a search of typedefs for uint32_t on my system I see that it is
>defined in several files, including /usr/include/stdint.h.
>>For some reason it is not being defined when you build libnet.  You
>could try adding:
>>#include <stdint.h>
>>before the line
>>#include <libnet.h>
>>in nmc_sys_defs.h
>>and see if that fixes the problem.
>>Mark
>>________________________________
>>Sent: Thu 11/19/2009 11:28 PM
>>To: tech-talk
>>Cc: Mark Rivers
>>Subject: error building mca6-11
>>hi,
>>when I tried to compile the mcaR6-11/10, I met following errors:
>>/usr/bin/gcc-4.2 -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
>-D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux
>-D_REENTRANT -ansi   -O3   -Wall     -g `libnet-config --defines`   -m32
>-g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux
>-I../../../include
>-I/usr/local/epics/r3.14.10/modules/soft/seq/2-0-12/include
>-I/usr/local/epics/r3.14.10/modules/soft/calc/2-6-7/include
>-I/usr/local/epics/r3.14.10/modules/soft/sscan/2-6-5/include
>-I/usr/local/epics/r3.14.10/modules/soft/busy/1-1/include
>-I/usr/local/epics/r3.14.10/modules/soft/std/2-6/include
>-I/usr/local/epics/r3.14.10/modules/soft/asyn/4-12/include
>-I/usr/local/epics/r3.14.10/modules/soft/mca/6-11/include/os/Linux
>-I/usr/local/epics/r3.14.10/base/include/os/Linux
>-I/usr/local/epics/r3.14.10/base/include        ../nmc_comm_subs_1.c
>>In file included from /usr/include/libnet.h:124,
>>                 from ../nmc_sys_defs.h:56,
>>                 from ../nmc_comm_subs_1.c:69:
>>/usr/include/./libnet/libnet-functions.h:1432: error: expected '=',
>',', ';', 'asm' or '__attribute__' before 'u_int32_t'
>>make[3]: *** [nmc_comm_subs_1.o] Error 1
>>make[3]: Leaving directory
>`/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp/CanberraSrc/O.li
>nux-x86'
>>make[2]: *** [install.linux-x86] Error 2
>>make[2]: Leaving directory
>`/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp/CanberraSrc'
>>make[1]: *** [CanberraSrc.install] Error 2
>>make[1]: Leaving directory
>`/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp'
>>make: *** [mcaApp.install] Error 2
>>root@cow1:/usr/local/epics/r3.14.10/modules/soft/mca/6-11#
>>Any suggestion?  thanks a lot.
>>ps, I use ubuntu, libnet1 with apt-get install ,not from source
>compilation.
>>Best regards
>>Geyang  2009-11-20
>Best regards
>Geyang 2009-11-20
Best regards
Geyang 2009-11-21
RE: RE: RE: error building mca6-11 Mark Rivers
error building mca6-11 Silver
Prev: Re: error building mca6-11 Bruce Hill
Next: RE: RE: RE: error building mca6-11 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: error building mca6-11 Mark Rivers
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
