1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: error building mca6-11
To: [email protected]
Date: Fri, 20 Nov 2009 18:51:31 -0800
I had a similar problem where I needed to compile some code
I was sharing with a non-epics app and I needed to compile it
without -ansi.
Turning it off in epics base config files is asking for trouble as it
will affect all compiles of base, modules, IOC's, etc.
Since -ansi is selecting the language standard, you can't just turn it off
with a compile flag.   Instead, you have to select a different language
standard.    The default gnu std for c files is gnu89, but others are
available as well, such as c89, c99, gnu99, etc.    See the gcc man page
for details.
For my directory that had this problem, I added the following line in that
directory's Makefile after including $(TOP)/configure/CONFIG.
   USR_CFLAGS      +=  -std=gnu99
- Bruce Hill
Silver wrote:
hi,  Michael:
    so how to solve it? close the ansi switch in epics base's configure files? will it influence the base?
======= At 2009-11-20, 22:41:31 you wrote: =======
This is an '-ansi' problem.
On my Debian system (libnet 1.1.2.1-2) line 1432 of libnet-functions.h
looks like
inline u_int32_t
The 'inline' keyword isn't part of ANSI C89 and can't be used when
compiling with '-ansi', which EPICS Base does by default.
Michael Davidsaver
NSLSII Controls Group
Brookhaven National Lab
-----Original Message-----
[email protected]] On Behalf Of Silver
Sent: Friday, November 20, 2009 12:28 AM
To: tech-talk
Subject: error building mca6-11
hi,
when I tried to compile the mcaR6-11/10, I met following errors:
/usr/bin/gcc-4.2 -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -
D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -
D_REENTRANT -ansi   -O3   -Wall     -g `libnet-config --defines`
-m32
-g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -
I../../../include  -I/usr/local/epics/r3.14.10/modules/soft/seq/2-0-
12/include
-I/usr/local/epics/r3.14.10/modules/soft/calc/2-6-7/include
-I/usr/local/epics/r3.14.10/modules/soft/sscan/2-6-5/include  -
I/usr/local/epics/r3.14.10/modules/soft/busy/1-1/include  -
I/usr/local/epics/r3.14.10/modules/soft/std/2-6/include    -
I/usr/local/epics/r3.14.10/modules/soft/asyn/4-12/include -
I/usr/local/epics/r3.14.10/modules/soft/mca/6-11/include/os/Linux -
I/usr/local/epics/r3.14.10/modules/soft/mca/6-11/include -
I/usr/local/epics/r3.14.10/base/include/os/Linux -
I/usr/local/epics/r3.14.10/base/include        ../nmc_comm_subs_1.c
In file included from /usr/include/libnet.h:124,
                 from ../nmc_sys_defs.h:56,
                 from ../nmc_comm_subs_1.c:69:
/usr/include/./libnet/libnet-functions.h:1432: error: expected '=',
',', ';', 'asm' or '__attribute__' before 'u_int32_t'
make[3]: *** [nmc_comm_subs_1.o] Error 1
make[3]: Leaving directory
`/usr/local/epics/r3.14.10/modules/soft/mca/6-
11/mcaApp/CanberraSrc/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory
`/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp/CanberraSrc'
make[1]: *** [CanberraSrc.install] Error 2
make[1]: Leaving directory
`/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp'
make: *** [mcaApp.install] Error 2
root@cow1:/usr/local/epics/r3.14.10/modules/soft/mca/6-11#
Any suggestion?  thanks a lot.
ps, I use ubuntu, libnet1 with apt-get install ,not from source
compilation.
Best regards
Geyang  2009-11-20
Best regards
Geyang 2009-11-21
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 94
Menlo Park, CA  94025
RE: error building mca6-11 Mark Rivers
error building mca6-11 Silver
RE: error building mca6-11 Davidsaver, Michael
Re: RE: error building mca6-11 Silver
Prev: Re: RE: error building mca6-11 Silver
Next: Re: RE: RE: error building mca6-11 Silver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: error building mca6-11 Mark Rivers
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
