1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RE: error building mca6-11
To: "Davidsaver, Michael" <[email protected]>, "tech-talk" <[email protected]>
Date: Sat, 21 Nov 2009 10:01:28 +0800
hi,  Michael:
    so how to solve it? close the ansi switch in epics base's configure files? will it influence the base?
======= At 2009-11-20, 22:41:31 you wrote: =======
>This is an '-ansi' problem.
>On my Debian system (libnet 1.1.2.1-2) line 1432 of libnet-functions.h
>looks like
>> inline u_int32_t
>The 'inline' keyword isn't part of ANSI C89 and can't be used when
>compiling with '-ansi', which EPICS Base does by default.
>Michael Davidsaver
>NSLSII Controls Group
>Brookhaven National Lab
>> -----Original Message-----
>> From: [email protected] [mailto:tech-talk-
>> [email protected]] On Behalf Of Silver
>> Sent: Friday, November 20, 2009 12:28 AM
>> To: tech-talk
>> Subject: error building mca6-11
>> hi,
>> when I tried to compile the mcaR6-11/10, I met following errors:
>> /usr/bin/gcc-4.2 -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -
>> D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -
>> D_REENTRANT -ansi   -O3   -Wall     -g `libnet-config --defines`
>-m32
>> -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -
>> I../../../include  -I/usr/local/epics/r3.14.10/modules/soft/seq/2-0-
>> 12/include
>-I/usr/local/epics/r3.14.10/modules/soft/calc/2-6-7/include
>> -I/usr/local/epics/r3.14.10/modules/soft/sscan/2-6-5/include  -
>> I/usr/local/epics/r3.14.10/modules/soft/busy/1-1/include  -
>> I/usr/local/epics/r3.14.10/modules/soft/std/2-6/include    -
>> I/usr/local/epics/r3.14.10/modules/soft/asyn/4-12/include -
>> I/usr/local/epics/r3.14.10/modules/soft/mca/6-11/include/os/Linux -
>> I/usr/local/epics/r3.14.10/modules/soft/mca/6-11/include -
>> I/usr/local/epics/r3.14.10/base/include/os/Linux -
>> I/usr/local/epics/r3.14.10/base/include        ../nmc_comm_subs_1.c
>> In file included from /usr/include/libnet.h:124,
>>                  from ../nmc_sys_defs.h:56,
>>                  from ../nmc_comm_subs_1.c:69:
>> /usr/include/./libnet/libnet-functions.h:1432: error: expected '=',
>> ',', ';', 'asm' or '__attribute__' before 'u_int32_t'
>> make[3]: *** [nmc_comm_subs_1.o] Error 1
>> make[3]: Leaving directory
>> `/usr/local/epics/r3.14.10/modules/soft/mca/6-
>> 11/mcaApp/CanberraSrc/O.linux-x86'
>> make[2]: *** [install.linux-x86] Error 2
>> make[2]: Leaving directory
>> `/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp/CanberraSrc'
>> make[1]: *** [CanberraSrc.install] Error 2
>> make[1]: Leaving directory
>> `/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp'
>> make: *** [mcaApp.install] Error 2
>> root@cow1:/usr/local/epics/r3.14.10/modules/soft/mca/6-11#
>> Any suggestion?  thanks a lot.
>> ps, I use ubuntu, libnet1 with apt-get install ,not from source
>> compilation.
>> Best regards
>> Geyang  2009-11-20
Best regards
Geyang 2009-11-21
Re: error building mca6-11 Bruce Hill
error building mca6-11 Silver
RE: error building mca6-11 Davidsaver, Michael
Prev: Leybold Vacuum INIVAC IM540 David Dudley
Next: Re: error building mca6-11 Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: error building mca6-11 Davidsaver, Michael
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
