1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Remote I/O
To: Paul Hamadyk <[email protected]>
Date: Thu, 17 Dec 2009 09:07:35 -0500
Paul Hamadyk wrote:
On Thu, 2009-12-17 at 08:08 -0500, Wesley Moore wrote:
At the FEL here at JLAB, we have several newer systems running Omron C-Series PLCs. The systems currently running are the Laser Personal Safety System, Turning Mirror Cassettes (motor control for optics), and our UV vacuum system. The PLCs are all programmed over Ethernet using Omron's CX-Programmer and an EPICS Ethernet driver is used for communication to the PLCs memory. I've not had much hassle in maintaining an IOC app and PLC logic for a given system. Usually the logic is only on one side depending on the requirements. I've scripted the creation of address files for generating the db. The address file created contains all the memory mapping and comments, providing great documentation of each system. Haven't heard this mentioned, but one other benefit we have deployed was the use of touchscreens for interactions with these PLC systems. For the minimal programming required, they have been a valuable resource in the flexibility they provide for local and remote control (using serial and Ethernet).
Wesley
We also use Omron PLCs, mostly CJ1s, and communicate using Hostlink or
FINS (Factory Interface Network Service) in a Hostlink wrapper via the
serial port (using streams and asyn). I am just performing some speed
comparisons between the serial port and the ETN21 Ethernet module using
FINS/UDP and FINS/TCP.
You say that "an EPICS Ethernet driver is used for communication to the
PLCs memory". Is that via FINS?
Paul.
I'm using the CJ1's as well paired with the ETN21 Ethernet module. I believe one I'm using has the built in Ethernet but it's basically the same. The Ethernet driver uses the FINS protocol. I can read/write bits or words to the PLC. The memory areas I read/write to are DM, CIO, WR, and HR. I've found pretty quick that reading by word and splitting out the bits to individual bi and bo's was the way to go. Much faster that way. I've got the driver working in EPICS 3.13 and 3.14.
Wesley
begin:vcard
fn:Wesley Moore
n:Moore;Wesley
org:Thomas Jefferson National Accelerator Facility;Free Electron Laser
adr:Suite 19, MS 18;;12000 Jefferson Avenue;Newport News;VA;23606;USA
email;internet:[email protected]
title:FEL Computer Scientist
tel;work:(757) 269-6033
tel;fax:(757) 269-6384
tel;pager:(757) 584-6033
url:http://www.jlab.org/FEL/
version:2.1
end:vcard
Re: Remote I/O Paul Hamadyk
Remote I/O nick.rees
Re: Remote I/O Matthias Clausen
Re: Remote I/O Ralph Lange
RE: Remote I/O Dalesio, Leo
Re: Remote I/O Wesley Moore
Prev: Re: Remote I/O Paul Hamadyk
Next: Re: Remote I/O Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Remote I/O Paul Hamadyk
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
