Hi Eric,
Here is the output:
file /opt/local/lib/libX*
/opt/local/lib/libX11.6.3.0.dylib: Mach-O 64-bit dynamically
linked shared library x86_64
/opt/local/lib/libX11.6.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libX11.a: current ar archive random library
/opt/local/lib/libX11.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libX11.la: libtool library file
/opt/local/lib/libXau.6.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXau.a: current ar archive random library
/opt/local/lib/libXau.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXau.la: libtool library file
/opt/local/lib/libXdmcp.6.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXdmcp.a: current ar archive random library
/opt/local/lib/libXdmcp.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXdmcp.la: libtool library file
/opt/local/lib/libXext.6.4.0.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXext.6.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXext.a: current ar archive random library
/opt/local/lib/libXext.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXext.la: libtool library file
/opt/local/lib/libXft.2.1.13.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXft.2.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXft.a: current ar archive random library
/opt/local/lib/libXft.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXft.la: libtool library file
/opt/local/lib/libXm.4.0.2.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXm.4.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXm.a: current ar archive random library
/opt/local/lib/libXm.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXm.la: libtool library file
/opt/local/lib/libXmu.6.2.0.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXmu.6.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXmu.a: current ar archive random library
/opt/local/lib/libXmu.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXmu.la: libtool library file
/opt/local/lib/libXmuu.1.0.0.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXmuu.1.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXmuu.a: current ar archive random library
/opt/local/lib/libXmuu.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXmuu.la: libtool library file
/opt/local/lib/libXp.6.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXp.a: current ar archive random library
/opt/local/lib/libXp.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXp.la: libtool library file
/opt/local/lib/libXrender.1.3.0.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXrender.1.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXrender.a: current ar archive random library
/opt/local/lib/libXrender.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXrender.la: libtool library file
/opt/local/lib/libXt.6.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXt.a: current ar archive random library
/opt/local/lib/libXt.dylib: Mach-O 64-bit dynamically
/opt/local/lib/libXt.la: libtool library file
Bertrand
Quoting Eric Norum <[email protected]>:
Run
to tell you about the architectures supported by your MacPorts Motif
installation.
Eric Norum
[email protected]
- Compiling alh, MEDM on Snow Leopard (10.6.2) Bertrand H.J. Biritz
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Bertrand H.J. Biritz
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Eric Norum
<2009>
2025
2026
<2009>
2025
2026
