Looks like you have a few options.
1) Rebuild EPICS as 64-bit.
2) Rebuild the X11/Motif stuff as 32-bit.
3) Rebuild EPICS and X11/Motif as universal 32/64-bit.
I don't think that there's any problem with a 32-bit kernel running 64-bit applications.
Maybe EpicsHostArch.pl needs to be modified to emit x86_64 on appropriate architectures?
On Dec 21, 2009, at 10:37 AM, Bertrand H.J. Biritz wrote:
> Hi Eric,
> I didn't change whatever the default compilation is – just downloaded the various EPICS components and made the usual changes: setting the environmental variable EPICS_HOST_ARCH (darwin-x86 according to EpicsHostArch.pl) and for the extensions defining to use MacPort instead of Fink.
> One thing to note is the kernel isn't running in 64-bit mode.
> Bertrand
> On Dec 21, 2009, at 1:12 PM, Eric Norum wrote:
>> Are all your EPICS compiles specifying the 64-bit architecture as well?
>> On Dec 21, 2009, at 9:56 AM, Bertrand H.J. Biritz wrote:
>>> Hi Eric,
>>> Here is the output:
>>> file /opt/local/lib/libX*
>>> /opt/local/lib/libX11.6.3.0.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libX11.6.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libX11.a: current ar archive random library
>>> /opt/local/lib/libX11.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libX11.la: libtool library file
>>> /opt/local/lib/libXau.6.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXau.a: current ar archive random library
>>> /opt/local/lib/libXau.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXau.la: libtool library file
>>> /opt/local/lib/libXdmcp.6.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXdmcp.a: current ar archive random library
>>> /opt/local/lib/libXdmcp.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXdmcp.la: libtool library file
>>> /opt/local/lib/libXext.6.4.0.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXext.6.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXext.a: current ar archive random library
>>> /opt/local/lib/libXext.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXext.la: libtool library file
>>> /opt/local/lib/libXft.2.1.13.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXft.2.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXft.a: current ar archive random library
>>> /opt/local/lib/libXft.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXft.la: libtool library file
>>> /opt/local/lib/libXm.4.0.2.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXm.4.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXm.a: current ar archive random library
>>> /opt/local/lib/libXm.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXm.la: libtool library file
>>> /opt/local/lib/libXmu.6.2.0.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXmu.6.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXmu.a: current ar archive random library
>>> /opt/local/lib/libXmu.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXmu.la: libtool library file
>>> /opt/local/lib/libXmuu.1.0.0.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXmuu.1.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXmuu.a: current ar archive random library
>>> /opt/local/lib/libXmuu.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXmuu.la: libtool library file
>>> /opt/local/lib/libXp.6.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXp.a: current ar archive random library
>>> /opt/local/lib/libXp.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXp.la: libtool library file
>>> /opt/local/lib/libXrender.1.3.0.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXrender.1.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXrender.a: current ar archive random library
>>> /opt/local/lib/libXrender.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXrender.la: libtool library file
>>> /opt/local/lib/libXt.6.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXt.a: current ar archive random library
>>> /opt/local/lib/libXt.dylib: Mach-O 64-bit dynamically linked shared library x86_64
>>> /opt/local/lib/libXt.la: libtool library file
>>> Thanks,
>>> Bertrand
>>> Quoting Eric Norum <[email protected]>:
>>>> Run
>>>> to tell you about the architectures supported by your MacPorts Motif installation.
>>>> Eric Norum
>>>> [email protected]
>> Eric Norum
>> [email protected]
Eric Norum
[email protected]
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Bertrand H.J. Biritz
- Compiling alh, MEDM on Snow Leopard (10.6.2) Bertrand H.J. Biritz
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Eric Norum
<2009>
2025
2026
<2009>
2025
2026
