1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Compiling alh, MEDM on Snow Leopard (10.6.2)
To: Eric Norum <[email protected]>
Cc: TECHTALK Tech-Talk <[email protected]>
Date: Mon, 21 Dec 2009 14:43:55 -0500
Hi Eric,
I will try again once my dad no longer is using the machine :)
How do I force the EPICS 64-bit compilation?
Bertrand
On Dec 21, 2009, at 1:47 PM, Eric Norum wrote:
Looks like you have a few options.
1) Rebuild EPICS as 64-bit.
2) Rebuild the X11/Motif stuff as 32-bit.
3) Rebuild EPICS and X11/Motif as universal 32/64-bit.
I don't think that there's any problem with a 32-bit kernel running 64-bit applications.
Maybe EpicsHostArch.pl needs to be modified to emit x86_64 on appropriate architectures?
On Dec 21, 2009, at 10:37 AM, Bertrand H.J. Biritz wrote:
Hi Eric,
I didn't change whatever the default compilation is – just downloaded the various EPICS components and made the usual changes: setting the environmental variable EPICS_HOST_ARCH (darwin-x86 according to EpicsHostArch.pl) and for the extensions defining to use MacPort instead of Fink.
One thing to note is the kernel isn't running in 64-bit mode.
Bertrand
On Dec 21, 2009, at 1:12 PM, Eric Norum wrote:
Are all your EPICS compiles specifying the 64-bit architecture as well?
On Dec 21, 2009, at 9:56 AM, Bertrand H.J. Biritz wrote:
Hi Eric,
Here is the output:
file /opt/local/lib/libX*
/opt/local/lib/libX11.6.3.0.dylib: Mach-O 64-bit dynamically linked shared library x86_64 /opt/local/lib/libX11.6.dylib: Mach-O 64-bit dynamically linked shared library x86_64 /opt/local/lib/libX11.a: current ar archive random library /opt/local/lib/libX11.dylib: Mach-O 64-bit dynamically linked shared library x86_64
/opt/local/lib/libX11.la:              libtool library file
/opt/local/lib/libXau.6.dylib: Mach-O 64-bit dynamically linked shared library x86_64 /opt/local/lib/libXau.a: current ar archive random library /opt/local/lib/libXau.dylib: Mach-O 64-bit dynamically linked shared library x86_64
/opt/local/lib/libXau.la:              libtool library file
/opt/local/lib/libXdmcp.6.dylib: Mach-O 64-bit dynamically linked shared library x86_64 /opt/local/lib/libXdmcp.a: current ar archive random library /opt/local/lib/libXdmcp.dylib: Mach-O 64-bit dynamically linked shared library x86_64
/opt/local/lib/libXdmcp.la:            libtool library file
/opt/local/lib/libXext.6.4.0.dylib: Mach-O 64-bit dynamically linked shared library x86_64 /opt/local/lib/libXext.6.dylib: Mach-O 64-bit dynamically linked shared library x86_64 /opt/local/lib/libXext.a: current ar archive random library /opt/local/lib/libXext.dylib: Mach-O 64-bit dynamically linked shared library x86_64
/opt/local/lib/libXext.la:             libtool library file
/opt/local/lib/libXft.2.1.13.dylib: Mach-O 64-bit dynamically linked shared library x86_64 /opt/local/lib/libXft.2.dylib: Mach-O 64-bit dynamically linked shared library x86_64 /opt/local/lib/libXft.a: current ar archive random library /opt/local/lib/libXft.dylib: Mach-O 64-bit dynamically linked shared library x86_64
/opt/local/lib/libXft.la:              libtool library file
/opt/local/lib/libXm.4.0.2.dylib: Mach-O 64-bit dynamically linked shared library x86_64 /opt/local/lib/libXm.4.dylib: Mach-O 64-bit dynamically linked shared library x86_64 /opt/local/lib/libXm.a: current ar archive random library /opt/local/lib/libXm.dylib: Mach-O 64-bit dynamically linked shared library x86_64
/opt/local/lib/libXm.la:               libtool library file
/opt/local/lib/libXmu.6.2.0.dylib: Mach-O 64-bit dynamically linked shared library x86_64 /opt/local/lib/libXmu.6.dylib: Mach-O 64-bit dynamically linked shared library x86_64 /opt/local/lib/libXmu.a: current ar archive random library /opt/local/lib/libXmu.dylib: Mach-O 64-bit dynamically linked shared library x86_64
/opt/local/lib/libXmu.la:              libtool library file
/opt/local/lib/libXmuu.1.0.0.dylib: Mach-O 64-bit dynamically linked shared library x86_64 /opt/local/lib/libXmuu.1.dylib: Mach-O 64-bit dynamically linked shared library x86_64 /opt/local/lib/libXmuu.a: current ar archive random library /opt/local/lib/libXmuu.dylib: Mach-O 64-bit dynamically linked shared library x86_64
/opt/local/lib/libXmuu.la:             libtool library file
/opt/local/lib/libXp.6.dylib: Mach-O 64-bit dynamically linked shared library x86_64 /opt/local/lib/libXp.a: current ar archive random library /opt/local/lib/libXp.dylib: Mach-O 64-bit dynamically linked shared library x86_64
/opt/local/lib/libXp.la:               libtool library file
/opt/local/lib/libXrender.1.3.0.dylib: Mach-O 64-bit dynamically linked shared library x86_64 /opt/local/lib/libXrender.1.dylib: Mach-O 64-bit dynamically linked shared library x86_64 /opt/local/lib/libXrender.a: current ar archive random library /opt/local/lib/libXrender.dylib: Mach-O 64-bit dynamically linked shared library x86_64
/opt/local/lib/libXrender.la:          libtool library file
/opt/local/lib/libXt.6.dylib: Mach-O 64-bit dynamically linked shared library x86_64 /opt/local/lib/libXt.a: current ar archive random library /opt/local/lib/libXt.dylib: Mach-O 64-bit dynamically linked shared library x86_64
/opt/local/lib/libXt.la:               libtool library file
Bertrand
Quoting Eric Norum <[email protected]>:
Run
to tell you about the architectures supported by your MacPorts Motif installation.
Eric Norum
[email protected]
Eric Norum
[email protected]
Eric Norum
[email protected]
Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Eric Norum
Compiling alh, MEDM on Snow Leopard (10.6.2) Bertrand H.J. Biritz
Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Bertrand H.J. Biritz
Prev: Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Eric Norum
Next: Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
