1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Compiling alh, MEDM on Snow Leopard (10.6.2)
Cc: Eric Norum <[email protected]>, [email protected]
Date: Mon, 21 Dec 2009 18:55:42 -0500
Hi Andrew,
Thanks for the info.
Poor Janet and in fact all of the EPICS developers who constantly need to update the code in order to compile properly on all the various architectures – it certain keeps everyone busy :) It is much appreciated by all of us who rely on you!
In MacPorts I just tried installing openmotif with the "universal" variant but one of the dependences failed to compile:
<snip>
Building Xft2
Error: Target org.macports.build returned: shell command " cd "/opt/ local/var/macports/build/ _opt_local_var_macports_sources_rsync .macports.org_release_ports_x11_Xft2/work/libXft-2.1.14" && /usr/bin/ make -j2 all " returned error 2
Command output:   "_FcUtf8ToUcs4", referenced from:
      _XftDrawStringUtf8 in xftdraw.o
      _XftTextExtentsUtf8 in xftextent.o
      _XftTextRenderUtf8 in xftrender.o
<snip>
So, unless I did something incorrect it looks like there is an impasse for a while.
Bertrand
On Dec 21, 2009, at 3:39 PM, Andrew Johnson wrote:
On Monday 21 December 2009 13:56:09 Eric Norum wrote:
To build EPICS for 64-bit only, edit
I don't recommend this if you're wanting to build and run alh or StripTool with the result; AIUI neither of those programs works very well (if at all) when built for 64-bit. Janet has fixing them on her To Do list, but I don't
know how long it's going to take.  MEDM seems to be Ok though.
I guess that's one of the disadvantages of using the Darwin universal 32/64 build configuration, all the code has to work properly on both configurations.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Cyrus Reed
Compiling alh, MEDM on Snow Leopard (10.6.2) Bertrand H.J. Biritz
Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Bertrand H.J. Biritz
Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Eric Norum
Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Andrew Johnson
Prev: RE: september cut Jeff Hill
Next: Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Cyrus Reed
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
